Linksys LGS308-UK 8-Port Smart Switch
Quicklinx: 9DXVWS00 Mfr#: LGS308-UK
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
Hurry, only 2 left in stock!
£48.27 ex VAT
£57.92 inc VAT
Get the network performance your business deserves with the smart Gigabit switches from Linksys. Designed for business-class management, security, speed, and quality of service, Linksys smart Gigabit switches provide a network your business can grow on.
  • Quality of Service (QoS)
    Numerous QoS features ensure that traffic is prioritized properly to deliver the best possible user experience for real-time applications like voice and video along with bandwidth-intensive graphic/video file uploads and downloads. IGMP snooping limits IP multicast traffic to the ports that requested it, enabling the rest of the network to operate at peak efficiency.
  • Network security
    Port authentication prompts end-users to provide a username and password before they are permitted to pass data. User access can also be controlled through MAC filtering, which allows network access only to authorized devices or workstations. Port mirroring enables you to monitor the type of traffic being transmitted on the network.
  • Network expansion
    Linksys smart switches include features for quickly expanding and growing your network. Multiple high-bandwidth trunks between switches enhance availability and redundancy. Spanning Tree Protocol (STP) and storm control features help control planned or inadvertent cable loops, so you can confidently build a mesh of switches and quickly expand your network to support your growing workforce.
Linksys Business Smart LGS308 - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mpps
MAC addresses: 8000 , Active VLANs: 128 , QoS hardware entries: 4
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 2c, HTTP, HTTPS, TFTP
Flow control, DHCP support, VLAN support, IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Quality of Service (QoS), RADIUS support, Jumbo Frames support, LACP support, Port Security, IP-MAC binding, DHCP client, Dynamic VLAN Support (GVRP), Class of Service (CoS), tagged VLAN, 802.1x authentication, DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
AC 100/230 V (50/60 Hz)
21 cm x 10.4 cm x 2.5 cm
528 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP
Authentication Method
RADIUS
RAM
128 MB
Status Indicators
System, link/activity
8 x 1000Base-T RJ-45
United Kingdom
21 cm
10.4 cm
2.5 cm
528 g
Limited warranty - lifetime
50 °C
10 - 90%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
9DXV C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
9DXV C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.27
9DXV C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.36
9DXV C2G 2m Cat6a Shielded Patch - Blue In Stock £7.62
Ports: 8
Managed: Yes
POE: No
Brand: Linksys
Price Range Ex VAT: 0 - 50
