Linksys LGS124P-UK Unmanaged 24-Port PoE Switch
Quicklinx: 9DXTWS00 Mfr#: LGS124P-UK
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: No
POE: PoE+
£153.39 ex VAT
£184.06 inc VAT
Upgrade the data paths of your local wired network to information superhighways with Gigabit switches at the desktop. Accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed. Power over Ethernet (PoE) capability also carries electrical power to peripheral devices without the need for additional outlets.
  • Gigabit performance
    These unmanaged PoE switches offer Gigabit speeds to minimize transfer times and greatly enhance the ability to stream high-bandwidth files to connected devices without interference.
  • Power where you need it
    PoE support lets you deploy network systems such as wireless access, IP telephony, or video surveillance solutions more quickly and at a lower cost, without having to install separate power supplies for individual devices.
  • Plug-and-Play convenience
    Linksys unmanaged switches offer a quick and easy solution to extend your office network with plug-and-play installation.
  • Quality of Service (QoS) traffic prioritization
    QoS traffic prioritization gives precedence to particular devices or activities to ensure mission-critical data throughput is maintained regardless of network congestion. Auto-sensing ports automatically optimize speed for each connected device.
Linksys Business LGS124P - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE+) + 12 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
120 W
Performance
Bandwidth: 48 Gbps
MAC Address Table Size
8000 entries
Auto-sensing per device, Quality of Service (QoS), DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
AC 100/230 V (50/60 Hz)
44 cm x 20 cm x 4.4 cm
2.785 kg
United Kingdom
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
120 W
Performance
Bandwidth: 48 Gbps
8000 entries
Status Indicators
Port transmission speed, PoE, link/activity
12 x 1000Base-T RJ-45 PoE+ , 12 x 1000Base-T RJ-45
Internal power supply
17.65 Watt
Plug and Play, FCC Class A certified, UL, CB
United Kingdom
44 cm
20 cm
4.4 cm
2.785 kg
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
9DXT C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
Ports: 24
Managed: No
POE: PoE+
Brand: Linksys
