Linksys LGS124-UK Unmanaged 24-Port Switch
Quicklinx: 9DXQWS00 Mfr#: LGS124-UK
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: No
POE: No
£101.62 ex VAT
£121.94 inc VAT
The unmanaged switch offers gigabit speeds to minimize transfer times and greatly enhance the ability to stream high-bandwidth files to connected devices without interference. The Linksys unmanaged switch offers a quick and easy solution to extend your office network with Plug and Play installation.
  • Gigabit performance
  • Plug and Play convenience
  • Quality of Service (QoS) traffic prioritization
    QoS traffic prioritization provides the ability to give precedence to particular devices or activities to ensure mission critical data throughput is maintained regardless of network congestion. Auto-sensing ports automatically optimize speed for each connected device.
  • Power saving features
    Power saving features include auto power-down to disable unused ports, smart power for short cable runs, and a port status switch to control LED lights.
Linksys Business LGS124 - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
Bandwidth: 48 Gbps
MAC Address Table Size
8000 entries
Auto-sensing per device, Quality of Service (QoS), fanless, DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 100/230 V (50/60 Hz)
44 cm x 20.1 cm x 4.4 cm
2.29 kg
United Kingdom
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
Bandwidth: 48 Gbps
8000 entries
Status Indicators
Port transmission speed, link/activity
24 x 1000Base-T RJ-45
Internal power supply
11.89 Watt
Power Consumption Stand by
3.62 Watt
Plug and Play, FCC Class A certified, UL, CB
United Kingdom
44 cm
20.1 cm
4.4 cm
2.29 kg
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
9DXQ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
9DXQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
9DXQ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.56
Ports: 24
Managed: No
POE: No
Brand: Linksys
Price Range Ex VAT: 100 - 150
