The unmanaged switch offers gigabit speeds to minimize transfer times and greatly enhance the ability to stream high-bandwidth files to connected devices without interference. The Linksys unmanaged switch offers a quick and easy solution to extend your office network with Plug and Play installation.
Gigabit performance
The unmanaged switch offers gigabit speeds to minimize transfer times and greatly enhance the ability to stream high-bandwidth files to connected devices without interference. -
Plug and Play convenience
The Linksys unmanaged switch offers a quick and easy solution to extend your office network with Plug and Play installation. -
Quality of Service (QoS) traffic prioritization
QoS traffic prioritization provides the ability to give precedence to particular devices or activities to ensure mission critical data throughput is maintained regardless of network congestion. Auto-sensing ports automatically optimize speed for each connected device. -
Power saving features
Power saving features include auto power-down to disable unused ports, smart power for short cable runs, and a port status switch to control LED lights.
- Linksys Business LGS124 - switch - 24 ports - unmanaged - rack-mountable
- Switch - 24 ports - unmanaged
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000
- Performance
- Bandwidth: 48 Gbps
- MAC Address Table Size
- 8000 entries
- Auto-sensing per device, Quality of Service (QoS), fanless, DiffServ Code Point (DSCP) support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 100/230 V (50/60 Hz)
- 44 cm x 20.1 cm x 4.4 cm
- 2.29 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000
- Performance
- 8000 entries
- Status Indicators
- Port transmission speed, link/activity
- 24 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 11.89 Watt
- Power Consumption Stand by
- 3.62 Watt
- Plug and Play, FCC Class A certified, UL, CB
- Localisation
- United Kingdom
- 44 cm
- 20.1 cm
- 4.4 cm
- 2.29 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £2.27 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.18 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £7.05 |
