Linksys LGS108-UK Unmanaged 8-Port Switch
Quicklinx: 9DXNWS00 Mfr#: LGS108-UK
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: No
POE: No
14 in stock
£27.71 ex VAT
£33.25 inc VAT
Upgrade the data paths of your local wired network to information superhighways with Gigabit switches at the desktop. Accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed.
Linksys Business LGS108 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
MAC Address Table Size
4000 entries
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
AC 100/230 V (50/60 Hz)
16.8 cm x 9 cm x 2.6 cm
0.358 kg
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
4000 entries
Status Indicators
Port transmission speed, link/activity
8 x 1000Base-T RJ-45
External power adapter
Power Provided
12 V - 0.5 A
3.355 Watt
Power Consumption Stand by
0.997 Watt
Plug and Play
United Kingdom
16.8 cm
9 cm
2.6 cm
0.358 kg
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
9DXN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
Ports: 8
Managed: No
POE: No
Brand: Linksys
Price Range Ex VAT: 0 - 50
