Upgrade the data paths of your local wired network to information superhighways with Gigabit switches at the desktop. Accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed.
- Linksys Business LGS108 - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Bandwidth: 16 Gbps
- MAC Address Table Size
- 4000 entries
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
- Power
- AC 100/230 V (50/60 Hz)
- 16.8 cm x 9 cm x 2.6 cm
- 0.358 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- 4000 entries
- Status Indicators
- Port transmission speed, link/activity
- 8 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Power Provided
- 12 V - 0.5 A
- Voltage Required
- 3.355 Watt
- Power Consumption Stand by
- 0.997 Watt
- Plug and Play
- Localisation
- United Kingdom
- 16.8 cm
- 9 cm
- 2.6 cm
- 0.358 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £2.27 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.13 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £11.02 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.84 |
