Protect your business and enhance your situational awareness with the Linksys 1080p 3-magepixel outdoor night vision dome camera. Positioned outside any business, Linksys network cameras provide superior security, surveillance, and supervision.
- Linksys 1080p 3MP Outdoor Night Vision Dome Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - outdoor - vandal / waterproof
- Audio
- Yes: two-way audio capability
- Camera Mount Type
- Ceiling mount
- 0.9 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 3.2 x
- Max Resolution
- 2048 x 1536
- Motion Detection
- Optical Sensor Type
- CMOS
- Minimum Illumination
- 0.5 lux - colour - F1.4 , 0 lux - B&W - F1.4
- Focal Length Control
- Vari-focal
- Focal Length
- 3.3 mm - 10.5 mm
- Lens Iris
- Auto iris
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Power over Ethernet, Wide Dynamic Range (WDR), Motion Detection Technology, Privacy Mask Function, ePTZ, multi-streaming, Audio Detect, SD/SDHC-card slot
- Environmental Parameters (operating)
- -40 °C - 50 °C; 10 - 80% (non-condensing) relative humidity
- Audio Support
- Form Factor
- Dome
- Camera Mount Type
- Ceiling mount
- Wired
- 0.9 kg
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed - outdoor - vandal / waterproof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 2048 x 1536
- Motion Detection
- Infrared LEDs
- 12
- Video Capture
- 2048 x 1536 @ 18 fps , 1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps
Image Sensor
- CMOS
Lens Construction
- Vari-focal
- Optical Zoom
- 3.2 x
- Focal Length
- 3.3 mm - 10.5 mm
- Lens Iris
- Auto iris
- Horizontal Field of View (degree)
- 26 - 70
- Vertical Field of View (degree)
- 20 - 51
- Network Interface
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- FCC Class A certified, IC Class A, IP67, IK10
- Power Requirements
- PoE
- -40 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
