Product
Linksys LCAD03VLNOD-UK SMB grade Outdoor Dome 3M PoE Camera
Quicklinx: 9DYJWS00 Mfr#: LCAD03VLNOD-UK
Protect your business and enhance your situational awareness with the Linksys 1080p 3-magepixel outdoor night vision dome camera. Positioned outside any business, Linksys network cameras provide superior security, surveillance, and supervision.
Linksys 1080p 3MP Outdoor Night Vision Dome Camera - network surveillance camera
Network surveillance camera - fixed dome - outdoor - vandal / waterproof
Audio
Yes: two-way audio capability
Camera Mount Type
Ceiling mount
0.9 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
3.2 x
Max Resolution
2048 x 1536
Motion Detection
Optical Sensor Type
CMOS
Minimum Illumination
0.5 lux - colour - F1.4 , 0 lux - B&W - F1.4
Focal Length Control
Vari-focal
Focal Length
3.3 mm - 10.5 mm
Lens Iris
Auto iris
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Power over Ethernet, Wide Dynamic Range (WDR), Motion Detection Technology, Privacy Mask Function, ePTZ, multi-streaming, Audio Detect, SD/SDHC-card slot
Environmental Parameters (operating)
-40 °C - 50 °C; 10 - 80% (non-condensing) relative humidity
Audio Support
Camera Mount Type
Ceiling mount
Wired
0.9 kg
United Kingdom
Camera
Colour - Day&Night - fixed dome - outdoor - vandal / waterproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
2048 x 1536
Motion Detection
Infrared LEDs
12
Video Capture
2048 x 1536 @ 18 fps , 1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps
Image Sensor
CMOS
Lens Construction
Vari-focal
Optical Zoom
3.2 x
Focal Length
3.3 mm - 10.5 mm
Lens Iris
Auto iris
Horizontal Field of View (degree)
26 - 70
Vertical Field of View (degree)
20 - 51
Network Interface
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
FCC Class A certified, IC Class A, IP67, IK10
Power Requirements
PoE
-40 °C
50 °C
Relative Humidity (operating)
9DYJ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
9DYJ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.64
9DYJ C2G 2m Cat6a Shielded Patch - Blue In Stock £7.15
