Linksys LAPN600-UK Dual Band N600 2x2 PoE AP with SmartWiFi
Quicklinx: 9DYBWS00 Mfr#: LAPN600-UK
Type: Radio access point
Connectivity: Wireless
Speed: 600Mbps
Protocol: IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
£74.99 ex VAT
£89.98 inc VAT
The Linksys Business Wireless-N Access Point employs Wi-Fi technology (802.11n) to provide a fast, powerful wireless network that's ideal for today's tech-savvy businesses.
  • Fast transfer rate
    It provides high-speed connectivity at transfer rates of up to 600 Mbps for notebooks, smartphones, tablets, and other Wi-Fi enabled devices. With a Gigabit Ethernet port, wireless clients can enjoy the fastest speeds possible by maximizing wireless-to-wired performance.
  • Optimal wireless coverage
    The Linksys Wireless-N Access Point offers high power for better, wider wireless coverage for you and your business, strengthening your network connection in hard-to-reach areas.
  • Flexible deployment
    It supports deployment as a traditional access point or set up as a workgroup bridge to extend your wireless range coverage.
  • Easy to use
    Integrated with 802.3 af/at PoE capability to eliminate external adapters and facilitate optimal placement.
  • Advanced security
    Protect your network with advanced security features including Rogue AP detection, SSID to VLAN mapping, and 802.1X supplicant.
Linksys Business LAPN600 - radio access point
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16 , Virtual interfaces (VLANs): 17
Power Over Ethernet (PoE) Supported
PoE+
23.698 cm x 24.308 cm x 4.369 cm
489.95 g
Radio access point
23.698 cm
24.308 cm
4.369 cm
489.95 g
United Kingdom
External
Wireless
Data Transfer Rate
600 Mbps
Remote Management Protocol
SNMP, HTTP
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
System
VLAN support, Syslog support, E-mail alert, MAC address filtering, IPv6 support, wall mountable, Wi-Fi Multimedia (WMM) support, event log, Multiple SSID support, wireless bridge mode, reset button, 2T2R MIMO technology, rogue access point detection, ceiling mountable, security lock slot (cable lock sold separately), 802.1x authentication
Encryption Algorithm
WPA, WPA2, WEP
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1000Base-T (PoE+) - RJ-45
IC, FCC
PoE+
External power adapter
17 Watt
Limited warranty - lifetime
10 - 85% (non-condensing)
9DYB C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
9DYB C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
9DYB C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.04
9DYB C2G 2m Cat6a Shielded Patch - Blue In Stock £7.40
Speed: 600Mbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Linksys
Price Range Ex VAT: 50 - 100
