Linksys LAPAC1200-UK Dual Band AC 2x2 PoE AP with SmartWiFi
Quicklinx: 9DYCWS00 Mfr#: LAPAC1200-UK
Type: Radio access point
Connectivity: Wireless
Speed: 1200Mbps
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
Compatibility: PC
  • IEEE 802.11n
£109.90 ex VAT
£131.88 inc VAT
The Linksys Business Wireless-AC Dual Band Access Point delivers the next generation of Wi-Fi technology (802.11ac) to provide faster speed and more Wi-Fi capability than ever before for your everyday business.
  • Wi-Fi connectivity
    The Linksys Business Wireless-AC Dual Band Access Point supports the latest 802.11ac technology, a three time performance increase from 802.11n. Enhancements such as wider 80 MHz channels provide greater data bandwidth while operating in the less-crowded 5 GHz band space. With this increase in Wi-Fi freedom, wireless clients can experience faster speeds while maximizing their performance.
  • Flexible deployment
    The Linksys Business Wireless-AC Dual Band Access Point can be deployed as a typical access point, or set up as a workgroup bridge to extend your wireless range coverage.
  • Easy to use
    The Linksys Business Wireless-AC Dual Band Access Point is integrated with 802.3at PoE+ capability to eliminate extra power adapters and offers optimal placement. It also provides an intuitive web administrative interface, easy to set up and easy to use.
  • Advanced security over wireless
    The Linksys Business Wireless-AC Dual Band Access Point protects and secures your wireless network with business-class security features including Wi-Fi Protected Access (WPA/WPA2), 802.1x supplicant authentication, MAC-based ACL, rouge AP detection, SSID-to-VLAN mapping, wireless scheduler, and more.
Linksys Business LAPAC1200 - radio access point
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16 , Virtual interfaces (VLANs): 17
Power Over Ethernet (PoE) Supported
PoE+
23.698 cm x 24.308 cm x 4.369 cm
Radio access point
23.698 cm
24.308 cm
4.369 cm
United Kingdom
External
Wireless
Data Transfer Rate
1200 Mbps
Remote Management Protocol
SNMP, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Selectable Channels Qty
11
Status Indicators
System
VLAN support, Syslog support, E-mail alert, MAC address filtering, IPv6 support, wall mountable, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Multiple SSID support, PoE+, wireless bridge mode, reset button, 2T2R MIMO technology, rogue access point detection, ceiling mountable, security lock slot (cable lock sold separately), 802.1x authentication
Encryption Algorithm
WPA, WPA2, WEP
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1000Base-T (PoE+) - RJ-45
IC, FCC
PoE+
External power adapter
Limited warranty - lifetime
10 - 85% (non-condensing)
Speed: 1200Mbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Linksys
Price Range Ex VAT: 100 - 150
