Linksys EA8500-UK Dual Band AC2600 Gigabit Smart Wi-Fi Router
Quicklinx: BC9DWS00 Mfr#: EA8500-UK
Type: Wireless router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
Speed: 2.53Gbps
Rackmount or External: External
  • IEEE 802.11n
£187.38 ex VAT
£224.85 inc VAT
The Linksys EA8500 AC2600 Simultaneous Tri-Band Broadband Wireless-AC Router is designed to take your wireless network to the next level with the latest in wireless technology. Using the latest tri-band 802.11ac Wireless Technology the Linksys EA8500 is capable of speeds up to 2533Mbps. Packed full with features, the Linksys provides ultimate wireless range due to high power amplifiers and MU-MIMO technology.
The next level of online gaming and streaming
Take your gaming and streaming to the next level with the Linksys EA8500 AC2600 Wi-Fi Router. This Linksys EA8500 is equipped with a 1.4 GHz dual-core CPU and features MU-MIMO technology, so it can handle heavy-bandwidth activities and heavy network traffic at a combined speed of up to 2.53 Gbps, making it the ultimate in fast Wi-Fi technology.
Latest 802.11ac WiFi speeds
With wireless speeds of up to 2533Mbps (2.5Gbps), the Linksys EA8500 offers the fastest point-to-point speeds available. And unlike traditional routers that deliver two or three data streams, the Linksys EA8500 uses 4x4 AC--the latest in Wireless-AC (802.11ac) technology--to deliver four simultaneous, independent streams of data at speeds up to 2.53 Gbps, six times faster than Wireless-N. Ideal for streaming HD videos and playing online games, this router delivers blazing speeds and uninterrupted connectivity. As a result, you can enjoy online gaming and video streaming without annoying lag or buffering.
Using the Wireless-AC standard, the Linksys EA8500 also delivers innovative beamforming technology, enabling the router to strengthen the wireless signal to specific devices, rather than simply send out Wi-Fi in a general direction. Now you can experience faster network speeds, better wireless range, reduced interference from other devices, and stronger Wi-Fi connections.
MU-MIMO for simultaneous streaming
While current Wireless-AC routers rely on single-use MIMO (multiple-input, multiple-output) technologies, the Linksys EA8500 is equipped to handle MU-MIMO (multi-user MIMO) capabilities. The Linksys EA8500 can handle heavy network traffic and high-bandwidth activities on multiple devices at the same time. The latest in Wireless-AC technology, MU-MIMO effectively allows for simultaneous streaming and gaming on numerous devices without any speed degradation.
Supercharged CPU
With the Linksys EA8500, you can enjoy the latest in speed and performance--whether you're playing online games or streaming music or HD videos--thanks to our 1.4 GHz dual-core processor. This enterprise-class CPU revs up throughput to wired and wireless devices alike and promotes simultaneous high-speed processing, making it great for downloading or transferring large files or performing other data-intensive activities.
High speed ports for wired connections
To provide the fastest possible wired performance, we equipped the Linksys EA8500 with four Gigabit Ethernet ports, which are 10 times faster than Fast Ethernet. Using the USB 3.0 port, you can add external storage or other devices to share content across your network. For those with an external SATA storage device, the Linksys EA8500 is outfitted with a unique eSATA port for convenience and optimal data transfer rates. For flexibility, the eSATA connection can also serve as a USB 2.0 port.
Four high powered antennas
To provide you with outstanding Wi-Fi coverage and performance, the Linksys EA8500 can reach speeds of up to 2533 Mbps for reduced lag and buffering. Four external antennas project large, overlapping Wi-Fi patterns to remove dead spots and widen the router's range. The antennas can be adjusted to just the right position or detached for future upgrades.
Latest 802.11ac Wireless-AC Technology, Backward Compatible with a/b/g/n Devices
Simultaneous tri-band WiFi speeds up to 2533 Mbps on 2.4Ghz and 5GHz
Four (4) High power antennas for ultimate range and performance
Four (4) 10/100/1000 Gigabit Ethernet RJ45 Ports for wired devices
DLNA Certified Media Server for video streaming
Quality of Service (QoS) for Smoother HD Video
SimpleTap Technology-Add Wi-Fi Devices to Your Network
Standard Warranty: 2-Years
Linksys EA8500 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2.53 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec
Firewall protection, IPv6 support, VPN passthrough, parental control, Wi-Fi Protected Setup (WPS), reset button, MU-MIMO technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac
25.63 cm x 18.35 cm x 5.62 cm
715 g
Microsoft Windows 7, Apple MacOS X 10.5.8 or later, Microsoft Windows XP SP3, Microsoft Windows Vista SP1 or later, Apple MacOS X 10.6.1 or later, Apple MacOS X 10.7 Lion, Windows 8, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks
United Kingdom
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2.53 Gbps
PPTP, L2TP, IPSec
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac, IC, FCC
1.4 GHz
RAM
512 MB DDR3 SDRAM
Flash Memory
128 MB
Status Indicators
Power, WLAN, LAN, WPS, Internet
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0 / eSATA: 1 x 11 pin USB/eSATA
Aerial
Aerial
External detachable and internal
Antenna Qty
5
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
25.63 cm
18.35 cm
5.62 cm
715 g
Limited warranty - 1 year
10 - 80% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 2.53Gbps
Brand: Linksys
Price Range Ex VAT: 150 - 300
