Linksys EA7500 AC1900 Mu-Mimo Gigabit 802.11a/b/g/n/ac Router
Quicklinx: C0HHWS00 Mfr#: EA7500-UK
  • IEEE 802.11n
More than 50 in stock
£124.48 ex VAT
£149.37 inc VAT
The MAX-STREAM AC1900 Multi User-MIMO Router offers two dedicated Wi-Fi bands that deliver combined speeds of up to 1.9 Gbps. Users can manually assign high-bandwidth Wi-Fi activities such as 4K video streaming and online gaming to the high-speed 5 GHz band, while assigning older Wi - Fi devices and activities to the 2.4 GHz band.
MU-MIMO (Multi-User, Multiple-Input, Multiple-Output) technology ensures uninterrupted simultaneous Wi-Fi connections to devices such as HD streaming media players, 4K TVs, tablets, and game consoles. Multiple devices receive high-speed Wi-Fi at the same time and same speed. Your family can access the Internet at the same time without experiencing lag or buffering - at up to 2x the speed of a non-MU-MIMO router.
Enjoy fast-paced Wi-Fi activities such as online multiplayer gaming with the MAX-STREAM AC1900. Powered by a 1.4 GHz dual-core processor, it is capable of handling three simultaneous data streams, delivering improved Wi-Fi performance and faster Wi-Fi speeds to more devices.
  • Enjoy lag-free streaming with next-gen AC mu-mimo Wi-Fi router
  • Endless Wi-Fi entertainment in busy homes
  • Lag-free online gaming via powerful processor
  • High-speed wired connectivity with Gigabit Ethernet ports
    Connect more devices and share files at speeds 10x faster than Fast Ethernet with four Gigabit Ethernet ports. Connect a storage device and quickly transfer files or share devices such as printers across your Wi-Fi network using the USB 2.0 and USB 3.0 ports.
  • Improved Wi-Fi speed and range with beamforming
    Direct Wi-Fi signals to each of your mobile devices to increase signal strength and coverage with our MAX-STREAM Wi-Fi router using Beamforming technology. Play video games, listen to music, check emails, shop online, stream HD movies, and more, without having to worry about dropped signals.
Linksys EA7500 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.9 Gbps
Reset button, 3T3R MIMO technology, beamforming technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
25.7 cm x 5.6 cm x 18.4 cm
558 g
Microsoft Windows 7, Apple MacOS X 10.x or later, Windows 8.1
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.9 Gbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, 128-bit AES, WPA2-Enterprise
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, FCC Class B certified
1.4 GHz
Status Indicators
WAN, LAN
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
25.7 cm
5.6 cm
18.4 cm
558 g
Type: Wireless router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 1.9Gbps
Brand: Linksys
Price Range Ex VAT: 100 - 150
