Linksys EA6900 AC1900 802.11ac router
Sale Price! - Was £139.44
Quicklinx: 959GWS00 Mfr#: EA6900-UK
Type: Wireless router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
Speed: 1900Mbps
Rackmount or External: External
  • IEEE 802.11n
£120.37 ex VAT
£144.44 inc VAT
The Linksys EA6900 AC1900 Simultaneous Dual-Band Broadband Wireless-AC Router is designed to take your wireless network to the next level with the latest in wireless technology. Using the latest Draft 802.11ac Wireless Technology the Linksys EA6900 is capable of speeds up to 600Mbps + 1300Mbps. Packed full with features, the Linksys provides ultimate wireless range due to high power amplifiers and SpeedBoost technology. With Connect Cloud, the Linksys EA6900 allows you to access your home network from anywhere, making this Linksys Smart Wi-Fi Router the future for home networking.
Key Features
Latest 802.11ac Wireless-AC Technology*
Backward Compatible with a/b/g/n Devices
Ultimate Speeds - Up to 600 + 1300 Mbps*
High Power Amplifiers for Ultimate Range*
SpeedBoost Technology for Increased Signal Strength
WPA2 Encryption and SPI Firewall and IPv6 Enabled
Four 10/100/1000 Gigabit Ethernet Ports
2 USB Ports to Simultaneously Share Printers and Storage**
3D Antenna Array Allows for Wall Mounted or Table Top Display
DLNA Certified Media Server for video streaming
Quality of Service (QoS) for Smoother HD Video
SimpleTap Technology-Add Wi-Fi Devices to Your Network
Connect Cloud
Now available for Linksys EA6900 and other Smart Wi-Fi Routers in the series, Connect Cloud gives you anytime, anywhere access to your home network. This revolutionary new technology delivers a host of free apps for your router, and that's only the beginning. As new devices and ways of interacting with your home emerge, Connect Cloud will keep expanding with new apps to enrich your connected lifestyle.
Create your wireless home network: Linksys Smart Wi-Fi Routers make it fast and easy.
Register your network online: Go to CiscoConnectCloud.com to open your account.
Customise with apps: Enhance your connected home with the apps of your choice.
Building the Future Together
As the world networking leader, Linksys is partnering with cutting edge appliance and device manufacturers to build the smart home of tomorrow. In that home, you will experience easier living through a variety of smart devices that will be connected to your home network. As more and more apps are released for Linksys Smart Wi-Fi Routers, it will become the key to running tomorrow's connected home.
  • Wireless AC technology
    The Linksys EA6900 uses the next generation Wireless AC technology for powerful networking.
  • Dual band 2.4+5 GHz
    Double the bandwidth to maximize wireless throughput.
  • Beamforming technology
    Focuses wireless signal from router to the client device for optimal performance.
  • USB ports
    Add external storage or other devices to share across your network. USB 3.0 transfer rate is 10x faster than USB 2.0.
  • DLNA certified media server
    Easily search for and play media (video, music, images) across your network.
  • Advanced security
    Wireless WPA/WPA2 encryption and SPI firewall help keep your network safely connected.
  • Guest access
    Easily secure your network while providing guests with Wi-Fi access.
  • Easy setup
    Simple installation, no CD required.
  • Parental controls
    Easily manage access to Internet by device with ability to create schedule and specific websites. Monitor at home or while away with Smart Wi-Fi using your computer browser or smartphone.
  • Linksys smart Wi-Fi
    Enhanced wireless router web interface. Monitor and control your home network from anywhere using computer browser or smartphone.
  • Device priority quality of service
    Wi-Fi traffic prioritization for smooth HD video performance.
  • Adjustable external antennas
    Adjust antennas for optimal wireless Wi-Fi performance.
Linksys EA6900 - wireless router - 802.11a/b/g/n/ac (draft) - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band
2.4 GHz / 5 GHz
Stateful Packet Inspection (SPI), IPv6 support, parental control, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, DLNA Media Server, 3T3R MIMO technology, SimpleTap technology
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft)
25.62 cm x 4.01 cm x 18.45 cm
534 g
Microsoft Certification
Compatible with Windows 7
Microsoft Windows 7, Microsoft Windows XP SP3 or later, Apple MacOS X 10.5.8 or later, Microsoft Windows Vista SP1 or later, Apple MacOS X 10.6.1 or later, Apple MacOS X 10.7 or later, Windows 8
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA, WPA2, WEP
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft), ICES-003, RSS-210, FCC, WEEE, LVD
Status Indicators
Power, WAN, LAN, WPS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
1 x network cable
25.62 cm
4.01 cm
18.45 cm
534 g
Limited warranty - 1 year
10 - 80% (non-condensing)
Network Adaptors (1)
Expand your network
959G C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.69
Other bundles (6)
959G C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
959G C2G 5m USB 2.0 A/B Cable - Black In Stock £5.10
959G C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.94
959G C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.96
959G C2G USB Superbooster Extender Kit In Stock £38.32
959G C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac (draft)
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 1900Mbps
Brand: Linksys
Price Range Ex VAT: 100 - 150
