Linksys EA6200-UK AC900 Smart Wifi Router
Quicklinx: 9372WS00 Mfr#: EA6200-UK
  • IEEE 802.11n
Wireless AC technology was developed to optimize video streaming experiences. Providing gigabit Wi-Fi speeds allows for content to download faster and large video or music files to sync more quickly. With an increasing number of Wi-Fi devices in the home and greater Internet consumption, this wireless standard will help meet your digital lifestyle demands. As your devices and Wi-Fi usage increases, make sure you have the latest wireless technology to get the most out of your connected experiences.
Wireless-AC technology
Built with leading 802.11ac wireless technology, your router offers maximum speed and range to create an ultra-powerful network designed for home theater performance. Connect your computers, Internet-ready TVs, game consoles, smartphones and other Wi-Fi devices at blazingly fast transfer rates for an unrivaled experience.
The power of dual band
Double your network bandwidth with simultaneous dual-band wireless-AC. The dual-band feature is designed to avoid interference and optimize throughput for smoother and faster HD video streaming, file transfers, and wireless gaming.
SpeedBoost
Higher quality antenna technology helps maintain high speeds across greater distances throughout your home.
Advanced security
Keep Wi-Fi freeloaders and Internet threats at bay with WPA2 encryption and SPI firewall to help keep your network protected.
Benefits of gigabit
Use the four Gigabit Ethernet (10/100/1000) ports for quick file sharing (up to 10× faster than standard Ethernet) between other Gigabit-enabled devices like computers and servers.
Built-in USB port and DLNA media server
The USB port let you add an external USB drive to your network and share files at home or over the Internet. It also features a built-in DLNA media server for seamless streaming of your video and media files to an Xbox 360, PS3, or other DLNA-compatible device. You can also connect a USB printer and share it across your network.
  • A way to optimize your connected life
    The Linksys Smart Wi-Fi Router with AC wireless technology includes Linksys SMART Wi-Fi to give you visibility into your home network from anywhere at any time. With your Linksys SMART Wi-Fi router you have the opportunity to get an ever-growing set of capabilities through mobile apps. These mobile apps will empower you to easily enhance and control your connected life.
  • Ultimate wireless speed
    The Linksys SMART Wi-Fi Router EA6200 is built with the latest Draft 802.11 ac wireless technology for speeds approximately 3x faster than Wireless-N. The EA6200 is ideal for fast HD video and media streaming.
  • SimpleTap technology
    Easily connect Wi-Fi devices to your home network with a push of a button (WPS) or a tap. Through the Linksys SMART Wi-Fi mobile app, you can use Wi-Fi protected setup to easily add devices without having to go to your router. Once you have a Linksys SMART Wi-Fi account, you can use the included SimpleTap card to easily add NFC-enabled mobile devices by tapping your card on the NFC-enabled device.
  • 1 USB 3.0 port
    Simultaneously access and share your stored USB content and printer.
  • Broad wireless compatibility
    Connect computers, HDTVs, media players, game consoles, smartphones, printers and more to your network and Internet connection. The Linksys SMART Wi-Fi Router EA6200 is backward compatible with a/b/g/n Devices.
  • The power of dual band
    Double your network bandwidth with dual-band N designed to help avoid interference and maximize throughput for smoother HD video streaming, file transfers, and wireless gaming.
  • Benefits of Gigabit
    Use the four Gigabit ports for quick file sharing, 10x faster than standard Ethernet, between other Gigabit-enabled devices.
  • Beamforming technology
    Higher quality antenna technology helps to maintain high speeds across greater distances throughout your home for maximum wireless coverage and in-home mobility.
  • Advanced security
    Help keep your network and personal information protected with advanced WPA2 encryption and integrated firewall.
  • Quality of Service
    Traffic prioritization technology delivers smoother performance for music, voice and video.
Linksys EA6200 - wireless router - Wi-Fi 5 - desktop, wall-mountable
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band
2.4 GHz / 5 GHz
Stateful Packet Inspection (SPI), IPv6 support, parental control, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), port forwarding, reset button, DLNA Media Server, port triggering, SimpleTap technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft)
25.6 cm x 18.4 cm x 4 cm
501 g
Microsoft Windows 7, Apple MacOS X 10.5.8 or later, Microsoft Windows XP SP3, Microsoft Windows Vista SP1 or later, Apple MacOS X 10.6.1 or later, Apple MacOS X Lion 10.7, Windows 8, Apple OS X 10.8 Mountain Lion
United Kingdom
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA, WPA2, WEP
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft), IC, FCC
Status Indicators
Port status, power
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
25.6 cm
18.4 cm
4 cm
501 g
10 - 80% (non-condensing)
9372 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.56
