The Linksys EA6100 Smart AC1200 Simultaneous Dual-Band WiFi Broadband Router features high-speed Wireless-AC technology and Smart Wi-Fi software to deliver next-generation home network performance. This Linksys EA6100 WiFi Router brings next-generation wireless speed to all your devices and comes equipped with Smart Wi-Fi software which allows users to monitor and control their home network from anywhere, anytime, using a smartphone.
Smart Wi-Fi apps: A growing suite of apps offers improved opportunities to control one's home network
Easy setup: Simple installation requires no CD
Next-generation wireless speed
This Linksys EA6100 WiFi Router brings next-generation wireless speed to all your devices. Featuring USB 2.0 and four Fast Ethernet ports along with the latest Wireless-AC technology, This Linksys EA6100 WiFi Router provides fast, reliable speeds for bandwidth-hungry devices. By leveraging dual bands with up to N300 Mbps + AC867 Mbps, data traffic can flow quickly and with minimal buffering - meaning gaming, media streaming and general Internet activities can happen simultaneously, keeping all users happy.
This Linksys EA6100 WiFi Router comes equipped with Smart Wi-Fi software, allowing users to monitor and control their home network from anywhere, anytime, using a smartphone. The Smart Wi-Fi feature allows users to see what devices are on the network, block devices from Internet access or specific websites, create a password-protected guest network and more.
Key Features
Up to 2.8 times faster than Wireless-N technology: Simultaneous dual-band speed up to N300 Mbps (2.4 GHz) + AC867 Mbps (5 GHz)† for media-intense applications
Faster Transfer Rates: USB 2.0 and Fast Ethernet for sharing photos, video, data files or a printer across your network
Linksys Smart Wi-Fi: Monitor and control a home network from anywhere and at any time. Smart Wi-Fi allows users to prioritize devices or websites, gain parental control over inappropriate content, monitor network activity, turn Wi-Fi access on or off, and create select password-protected guest networks.
- Linksys EA6100 - wireless router - Wi-Fi - desktop, wall-mountable
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop, wall-mountable
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Stateful Packet Inspection (SPI), IPv6 support, parental control, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), port forwarding, reset button, DLNA Media Server, port triggering, SimpleTap technology
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP
- 20 cm x 17.4 cm x 3.2 cm
- 298 g
- System Requirements
- Microsoft Windows 7, Windows 8
- Localisation
- United Kingdom
- Enclosure Type
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Encryption Algorithm
- WPA, WPA2, WEP
- Authentication Method
- RADIUS
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IC, FCC
- Status Indicators
- Port status, power, WPS, Internet
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 20 cm
- 17.4 cm
- 3.2 cm
- 298 g
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
