Linksys EA6100-UK
Linksys EA6100-UK
Quicklinx: 9XFHWS00 Mfr#: EA6100-UK
  • IEEE 802.11n
The Linksys EA6100 Smart AC1200 Simultaneous Dual-Band WiFi Broadband Router features high-speed Wireless-AC technology and Smart Wi-Fi software to deliver next-generation home network performance. This Linksys EA6100 WiFi Router brings next-generation wireless speed to all your devices and comes equipped with Smart Wi-Fi software which allows users to monitor and control their home network from anywhere, anytime, using a smartphone.
Smart Wi-Fi apps: A growing suite of apps offers improved opportunities to control one's home network
Easy setup: Simple installation requires no CD
Next-generation wireless speed
This Linksys EA6100 WiFi Router brings next-generation wireless speed to all your devices. Featuring USB 2.0 and four Fast Ethernet ports along with the latest Wireless-AC technology, This Linksys EA6100 WiFi Router provides fast, reliable speeds for bandwidth-hungry devices. By leveraging dual bands with up to N300 Mbps + AC867 Mbps, data traffic can flow quickly and with minimal buffering - meaning gaming, media streaming and general Internet activities can happen simultaneously, keeping all users happy.
This Linksys EA6100 WiFi Router comes equipped with Smart Wi-Fi software, allowing users to monitor and control their home network from anywhere, anytime, using a smartphone. The Smart Wi-Fi feature allows users to see what devices are on the network, block devices from Internet access or specific websites, create a password-protected guest network and more.
Key Features
Up to 2.8 times faster than Wireless-N technology: Simultaneous dual-band speed up to N300 Mbps (2.4 GHz) + AC867 Mbps (5 GHz)† for media-intense applications Faster Transfer Rates: USB 2.0 and Fast Ethernet for sharing photos, video, data files or a printer across your network Linksys Smart Wi-Fi: Monitor and control a home network from anywhere and at any time. Smart Wi-Fi allows users to prioritize devices or websites, gain parental control over inappropriate content, monitor network activity, turn Wi-Fi access on or off, and create select password-protected guest networks.
Linksys EA6100 - wireless router - Wi-Fi - desktop, wall-mountable
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Stateful Packet Inspection (SPI), IPv6 support, parental control, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), port forwarding, reset button, DLNA Media Server, port triggering, SimpleTap technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP
20 cm x 17.4 cm x 3.2 cm
298 g
Microsoft Windows 7, Windows 8
United Kingdom
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA, WPA2, WEP
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IC, FCC
Status Indicators
Port status, power, WPS, Internet
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
20 cm
17.4 cm
3.2 cm
298 g
10 - 80% (non-condensing)
