Linksys E900 Wireless-N Broadband Router (300Mbps)
Quicklinx: 8QZDWS00 Mfr#: E900-UK
Type: Wireless router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g + 1 more
Speed: 300Mbps
Rackmount or External: External
  • IEEE 802.11n
More than 50 in stock
£14.69 ex VAT
£17.62 inc VAT
E900 Wireless-N300 Router is built with leading 802.11n technology, create a powerful home wireless network in minutes. Connect your computers, Internet-ready TVs, game consoles, smartphones, and other Wi-Fi devices at fast transfer rates for an unrivaled experience.
Keep Wi-Fi freeloaders and Internet threats at bay with WPA2 encryption and SPI firewall to help keep your network protected.
Ideal for:
Surfing the web and emailing
Networking smaller homes or apartments
Connecting devices
Key features*:
High speed (up to 300 Mbps) for fast wireless transfer rates
Reliable range with MIMO antenna technology
Four Ethernet ports to connect wired devices to the network
  • Wireless-N technology
    Built with leading 802.11n technology, create a powerful home wireless network in minutes. Connect your computers, Internet-ready TVs, game consoles, smartphones, and other Wi-Fi devices at fast transfer rates for an unrivaled experience.
  • Advanced security
  • Benefits of Fast Ethernet
    Use the four Fast Ethernet (10/100) ports for quick file sharing between computers and servers.
  • Home network ready
    Connect computers, printers, and more to your wireless network and the Internet. QoS traffic prioritization technology delivers maximum speed and performance so you can enjoy fast downloads and reliable gaming.
  • IPv6 enabled
    It supports the latest Internet protocol technology to future-proof your network.
Linksys E900 - wireless router - 802.11b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
RIP, static IP routing
128-bit encryption, NAT support, Stateful Packet Inspection (SPI), dynamic DNS server, MAC address filtering, IPv6 support, VPN passthrough, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, port forwarding, IPv4 support
IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
18.9 cm x 15.2 cm x 3.1 cm
202 g
United Kingdom
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Encryption Algorithm
128-bit WEP, WPA, WPA2
IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, UL, cUL, ICES-003, RSS-210, FCC
Status Indicators
Power, link/activity
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
18.9 cm
15.2 cm
3.1 cm
202 g
Limited warranty - 1 year
10 - 80% (non-condensing)
8QZD C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
8QZD C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
8QZD C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.20
8QZD C2G 2m Cat6a Shielded Patch - Blue In Stock £7.49
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 300Mbps
Brand: Linksys
Price Range Ex VAT: 0 - 50
