Upgrade your current Ethernet network to the power of Gigabit and improve your network performance.
Get speeds up to 10x faster than Fast Ethernet - perfect for quick file and media sharing between Gigabit devices.
Plug & PlayThis compact switch is designed to conserve desktop space and is easy to use - no configuration required. Simply connect computers, HDTVs, game consoles, media players and more, to instantly expand your home network.
Quality of ServiceQoS traffic prioritization technology delivers high performance so you can enjoy smooth video streaming and gaming.
Auto-sensing ports automatically optimize speed for each connected device.
Power SavingIncludes special features for optimal power efficiency.
-Auto power-down disables unused ports
-Sleep mode when all ports are inactive
-Smart power for short cable runs
-Port status switch to control LED lights
Benefits of Gigabit
Upgrade your current Ethernet network to the power of Gigabit and improve your network performance. Get speeds faster than Fast Ethernet - perfect for quick file and media sharing between Gigabit devices. -
Plug and play
This compact switch is designed to conserve desktop space and is easy to use - no configuration required. Simply connect computers, HDTVs, game consoles, media players and more, to instantly expand your home network. -
Quality of Service
QoS traffic prioritization technology delivers high performance so you can enjoy smooth video streaming and gaming. Auto-sensing ports automatically optimize speed for each connected device. -
Power saving
- Header / Model
- SE2500
- General / Product Type
- Gigabit Ethernet Switch
- Ports
- 5
- Data Transfer Rate
- 1000 Mbps
- Managed
- no
- Connection Type
- RJ45
- Dimensions & Weight / Depth
- 135 mm
- Dimensions & Weight / Height
- 60mm
- Dimensions & Weight / Weight
- .41 kg
- Dimensions & Weight / Width
- 255 mm
- Environmental Parameters / Max Operating Temperature
- 40 Celcius
- Environmental Parameters / Min Operating Temperature
- 0 Celcius
- Flash Memory / Installed Size
- 192KB
- Flash Memory / Technology
- Packet memory
- Flash Memory / Type
- Packet memory
- Header / Country Kits
- UK
- Header / Localization
- UK
- Header / Manufacturer
- Linksys
- Header / Packaged Quantity
- 1
- Interface Provided / Connector Qty (Network)
- 5
- Interface Provided / Connector Type
- RJ45
- Interface Provided / Type
- RJ45
- Interface Required / Connector Qty
- 5
- Interface Required / Connector Type
- RJ45
- Interface Required / Total Qty
- 5
- Interface Required / Type
- RJ45
- Miscellaneous / Colour
- Black
- Miscellaneous / Compliant Standards
- "CE Mark, EN 55022 Class B,
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
