The Linksys E1700 Wireless Router for cable Broadband is the latest member of the Linksys E-series family and offers the an increase in wireless range thanks to it's Wireless 802.11 technology and additional antennas. With Wireless-N speeds up to 300Mbps the Linksys E1700 is able to stream on all your wireless content to devices such as laptops, iPads, internet-enabled TVs, Blu-ray players and game consoles, over large distances, with ease. Additionally, the Linksys E1700 features a four built-in Gigabit Ethernet ports to supply high-speed connections to your wired devices.
Fast Wireless Speed: The Linksys E1700 offers fast speed to connect your computers, wireless printers and other Wi-Fi devices at transfer rates up to 300 Mbps speed.
Reliable Wireless Coverage: Built with leading 802.11n wireless technology, the Linksys E1700 offers reliable range to create a powerful wireless network. MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home.
Advanced Security: Keep Wi-Fi freeloaders and Internet threats at bay, The Linksys E1700 offersWPA/WPA2 encryption and SPI firewall to help keep your network protected.
Quick Install: Cisco Connect software helps you set up your home wireless network in three easy steps.
Easy to Manage: Cisco Connect software helps you customise your settings, and quickly add multiple devices to your network:
Create a separate, password protected network for guests
Limit access time and websites with Parental Controls
Access advanced network settings easily
Enjoy Wireless-N technology
Speeds up to N300 Mbps create a powerful wireless network. -
Detachable Antennas
Flexible placement options to optimize antenna position and achieve optimal range and performance. -
Faster transfer rates
4 Gigabit ports deliver 10x faster transfer rates than Ethernet for photos, video and data files. -
Advanced security
With WPA/WPA2 encryption and SPI firewall, you can be confident content on your wireless home network will remain protected.
- Linksys E1700 - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Wi-Fi Protected Setup (WPS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
- 18.87 cm x 15.17 cm x 3.12 cm
- 245 g
- Localisation
- United Kingdom
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Encryption Algorithm
- WPA, WPA2, WEP
- Authentication Method
- RADIUS
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, FCC
- Status Indicators
- Port status, power
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- 18.87 cm
- 15.17 cm
- 3.12 cm
- 245 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
