Linksys Dual Band AC1750 Access Point
Quicklinx: B75KWS00 Mfr#: LAPAC1750PRO-UK
  • IEEE 802.11n
Linksys Pro Series wireless AC dual band access points deliver data rates at up to 3x faster than the 802.11n standard. With bandwidth speeds up to 1750 Mbps and wider 80 MHz channels your wireless network can grow without losing speed. Linksys Pro Series wireless-AC dual band access point implements a captive portal to support secure and customized guest Wi-Fi access and can be used at many Wi-Fi hotspots to control wireless access in the area.
  • Wireless AC speed - up to 1750 Mbps
  • Single point control: cluster
    Cluster system management simplifies administration and management efforts with a single point control, simultaneously reducing the costs and complexity of managing multiple wireless access points.
  • Captive portal
  • 3-in-1 access point, WDS & workgroup bridge
    It supports deployment as a traditional access point, a wireless distribution system (WDS), or set up as a wireless bridge to extend wireless range.
  • Easy to use with PoE+
    Integrated 802.3at Power over Ethernet Plus (PoE+) capability eliminates external adapters and facilitate optimal placement.
  • Comprehensive network security
    Protect and secure your wireless network with business class security features including Wi-Fi Protected Access (WPA/WPA2), 802.1X supplicant authentication, MAC-based ACL, rogue AP detection, SSID-to-VLAN mapping, and more.
Linksys Pro Series LAPAC1750PRO - radio access point - Wi-Fi 5
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16 , Virtual interfaces (VLANs): 17
Power Over Ethernet (PoE) Supported
PoE+
23.8 cm x 24.7 cm x 4.33 cm
520 g
Radio access point
23.8 cm
24.7 cm
4.33 cm
520 g
United Kingdom
External
Wireless
Data Transfer Rate
1750 Mbps
Remote Management Protocol
SNMP, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
System
VLAN support, Syslog support, DiffServ support, E-mail alert, MAC address filtering, IPv6 support, wall mountable, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), Multiple SSID support, PoE+, wireless bridge mode, reset button, 3T3R MIMO technology, rogue access point detection, ceiling mountable, security lock slot (cable lock sold separately), 802.1x authentication
Encryption Algorithm
WPA, WPA2, WEP
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
1 x 1000Base-T (PoE+) - RJ-45
IC, FCC
PoE+
External power adapter
24 Watt
Limited warranty - lifetime
35 °C
10 - 85% (non-condensing)
B75K C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
