Linksys AE6000 Mini Dual-Band Wireless-AC USB Adapter (433Mb
Quicklinx: 8QYLWS00 Mfr#: AE6000-EU
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11n, IEEE 802.11a, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
£18.45 ex VAT
£22.14 inc VAT
Connect and upgrade your devices to the newest, most powerful wireless-AC technology.
Upgrade devices to Wireless-AC
High performance HD video and gaming
Unique mini design for easier mobility
Dual-Band to help avoid interference and maximize throughput
Maximum Speed
Up to 430 Mbps speed* on Wireless-AC 5 GHz band or up to 150 Mbps speed* on Wireless-N 2.4 GHz band*
Selectable Dual-Band
Operates at either 2.4 GHz on Wireless-N or 5 GHz on Wireless-AC to avoid wireless interference.
Advanced Security
Supports up to 128-bit encryption (WEP, WPA and WPA2).
Easy Setup
Easily connect using the Setup Wizard or by using the WPS button.
  • Maximum speed
    Up to 430 Mbps speed on wireless-AC 5 GHz band or up to 150 Mbps speed on wireless-N 2.4 GHz band.
  • Selectable Dual-Band
  • Advanced security
  • Easy setup
Linksys Mini AC Adapter AC580 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
3.5 cm x 1.5 cm x 0.8 cm
4 g
Europe
802.11ac
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Network adapter
External
USB 2.0
Europe
Wireless
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
128-bit encryption, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WEP
3.5 cm
1.5 cm
0.8 cm
4 g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11a
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac
Compatibility: PC
Brand: Linksys
