Connect and upgrade your devices to the newest, most powerful wireless-AC technology.
Upgrade devices to Wireless-AC
High performance HD video and gaming
Unique mini design for easier mobility
Dual-Band to help avoid interference and maximize throughput
Maximum Speed
Up to 430 Mbps speed* on Wireless-AC 5 GHz band or up to 150 Mbps speed* on Wireless-N 2.4 GHz band*
Selectable Dual-Band
Operates at either 2.4 GHz on Wireless-N or 5 GHz on Wireless-AC to avoid wireless interference.
Advanced Security
Supports up to 128-bit encryption (WEP, WPA and WPA2).
Easy Setup
Easily connect using the Setup Wizard or by using the WPS button.
Maximum speed
Up to 430 Mbps speed on wireless-AC 5 GHz band or up to 150 Mbps speed on wireless-N 2.4 GHz band. -
Operates at either 2.4 GHz on Wireless-N or 5 GHz on Wireless-AC to avoid wireless interference. -
Advanced security
Supports up to 128-bit encryption (WEP, WPA and WPA2). -
Easy setup
- Linksys Mini AC Adapter AC580 - network adapter
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 3.5 cm x 1.5 cm x 0.8 cm
- 4 g
- Localisation
- Europe
- Data Link Protocol
- 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Network adapter
- Form Factor
- External
- USB 2.0
- Localisation
- Europe
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Link/activity
- 128-bit encryption, Wi-Fi Protected Setup (WPS)
Aerial
- Antenna
- Internal
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WEP
- 3.5 cm
- 1.5 cm
- 0.8 cm
- 4 g
