Linksys AC2600 Dual Band Access Point POE+
Quicklinx: CC9CWS00 Mfr#: LAPAC2600-EU
  • IEEE 802.11n
The Linksys Business Pro Series Wireless-AC Dual-Band Access Point delivers comprehensive enterprise-grade software features and next-generation Wi-Fi MU-MIMO technology for high-density performance and faster speed for your everyday business.
Next Generation AC Wi-Fi Connectivity
Allows multiple clients to transmit data simultaneously, improving performance and productivity in high density wireless environments. Features 4x4 Dual-Band (2.4+5GHz) AC delivering combined speeds of up to 2.53Gbps* for faster, more robust wireless performance.
Seamless Roaming
Supports 802.11r and 802.11k standards, enabling 802.11r-enabled client devices to roam between access point with minimal dropped packets, enabling uninterrupted VoIP calls or video calls (such as Facetime).
Clustering (Single Point Control)
Clustering helps to reduce the costs and complexity of managing multiple wireless access points simultaneously simplifying administration and management
Captive Portal
Secure and customized guest Wi-Fi access. The captive portal is also used at many Wi-Fi hotspots to control wireless access in the area.
Flexible Deployment
Can be deployed as a typical access point, as a wireless distribution system (WDS), or as a workgroup bridge to extend your wireless range coverage.
Easy to Use with PoE+
Integrated with 802.3at PoE+ capability to eliminate extra power adapters and offer optimal placement. It also provides an intuitive Web administrative interface, easy to set up and easy to use.
Two Gigabit Ethernet ports with Link Aggregation
The 4x4 11AC radio is backed by Dual Gigabit Ethernet ports with Link Aggregation for a combined backhaul capacity of 2 Gbps, enabling maximum utilization of the 11AC radio.
Advanced Security Over Wireless
Protects and secures your wireless network with business class security features including Wi-Fi Protected Access (WPA/WPA2), 802.1X Supplicant Authentication, MAC and IP-Based ACL, Rogue AP Detection, SSID-to-VLAN Mapping, Wireless Scheduler, and more.
Key Features
  • Next-generation Wi-Fi 802.11ac with dual-band (2.4 GHz + 5 GHz) support and maximum data rate up to 2.53 Gbps
  • Integrated Power over Ethernet Plus (PoE+)
  • Gigabit Ethernet port speed
  • WDS Bridge and Workgroup Bridge Support
  • Captive Portal
  • Centralized Management via Clustering
  • Advanced security and preventions (802.1X Supplicant, SSID to VLAN mapping, ACL, etc.)
  • IPv6 support
  • AC Wi-Fi connectivity delivers robust wireless performance
    The LAPAC2600 Access Point leverages the latest Wireless-AC technology to ensure faster Wi-Fi speeds and increased productivity for your entire office. The access point features dual wireless bands (2.4 GHz and 5 GHz) and delivers combined speeds of up to 2.53 Gbps to support high-bandwidth activities such as video conferencing and cloud storage syncing.
  • Seamless roaming for uninterrupted connections
    Featuring support for 802.11r and 802.11k standards, the LAPAC2600 Access Point allows 802.11r-enabled client devices to roam seamlessly between access points. Your employees will be able to move freely across the office while conducting VoIP or video calls - without any interruptions due to dropped packets or missed handovers.
  • Simplified management with clustering
    The LAPAC2600 Access Point allows centralized management via Clustering to reduce the cost and complexity of managing multiple wireless access points. By enabling you to establish and manage an entire cluster of access points from a single point of control, this feature greatly streamlines administration and can save hours of technical labor. You can use it to configure multiple access points simultaneously and centralize network security.
  • Captive portal for secure guest access
    Control and customize guest Wi-Fi access with captive portal. The portal routes users to a special web page for authentication before they are allowed to access the Internet. Ideal for cafés, lobbies, and other Wi-Fi hotspots, this feature helps protect both your guests and your business from unwanted access.
  • PoE+ for streamlined installation
    Thanks to its PoE+ (Power over Ethernet Plus) capabilities, the LAPAC2600 Access Point can draw both power and data from a single Ethernet cable. There is no need for a separate power adapter or nearby electrical outlet: simply connect the LAPAC2600 to a PoE-enabled switch, and the access point can function using just one Ethernet cable. The LAPAC2600 Access Point also provides a Web administrative interface for intuitive installation and usage.
  • Advanced wireless security protects your data
    To ensure that your company's data is secure, the LAPAC2600 Access Point is equipped with an array of business-class security features. The access point gives your business full control over access rights with WPA/WPA2 security and 802.1X with RADIUS or Remote Authentication Dial-In User Service that provides administrators with a centralized way to authenticate users on the network. Rogue AP Detection helps administrators identify authorized access points across the network, while 802.1X Supplicant Authentication and Mac address filtering provide an additional layer of protection
Linksys Business LAPAC2600 - radio access point - Wi-Fi 5
Radio access point
External
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16
Mounting brackets, ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE+
23.7 cm x 24.3 cm x 4.37 cm
848 g
Radio access point
23.7 cm
24.3 cm
4.37 cm
848 g
Europe
External
Wireless
Data Transfer Rate
2.53 Gbps
Routing Protocol
IGMP, MLD
Remote Management Protocol
SNMP, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
System
IGMP snooping, Syslog support, DiffServ support, IPv6 support, Wireless Distribution System (WDS) support, Media Bandwidth Management (MBM), wall mountable, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, wireless bridge mode, reset button, clustering technology, Link Aggregation Control Protocol (LACP), rogue access point detection, e-mail notification, ceiling mountable, 4T4R MIMO technology, Captive Portal, security lock slot (cable lock sold separately), 802.1x authentication, MU-MIMO technology, scheduler, band steering, event notification, network diagnostics, SSID to VLAN mapping, dual image support
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.11k, IEEE 802.3at, IEEE 802.11r
Aerial
Antenna
Internal
1 x 1000Base-T (PoE+) - RJ-45 , 1 x 1000Base-T (management) - RJ-45
1 x network cable
IC, FCC
PoE+
External power adapter
24 Watt
Limited warranty - lifetime
10 - 85% (non-condensing)
