Linksys AC1200 Dual-Band Wi-Fi Range Extender
Quicklinx: C0HLWS00 Mfr#: RE6400-UK
Type: Wi-Fi range extender
Speed: 1200Mbps
Connectivity: Wireless
Pass-through Socket: No
£58.81 ex VAT
£70.57 inc VAT
Eliminate dead zones and boost the Wi-Fi signal from your existing router with the Linksys AC1200 BOOST EX Wi-Fi Range Extender (RE6400). The range extender features simple setup options which allow you to quickly determine optimal placement in relation to your router. It works with all Wi-Fi routers, including those from service providers, to deliver uninterrupted video and music streaming, smooth online gaming, and seamless content sharing.
This dual-band extender delivers AC1200 data transfer speeds (N300 + AC867 Mbps) for fast, uninterrupted Wi-Fi that you can enjoy in the far reaches of your home - even outdoors.
  • Up to N300 + AC867 Mbps speed
    Dual band wireless range extender brings speed and reliability, wherever you are.
  • Spot Finder technology
    Easy to use, mobile-guided range extender setup to extend Wi-Fi range throughout your home.
  • Eliminate dead zones and boost Wi-Fi up to 7500 square feet
    Easily expand your home Wi-Fi to enjoy uninterrupted streaming, smooth online gaming, and more with the Linksys AC1200 BOOST EX Wi-Fi Range Extender (RE6400). The AC1200 BOOST EX extends your existing Wi-Fi range up to 7500 square feet so you can enjoy a stronger Wi-Fi signal - even outdoors.
  • Works with all Wi-Fi routers
    The AC1200 BOOST EX is compatible with all Wi-Fi routers, including your existing unit or those from service providers. There's no need to modify your router's settings when installing the extender - you won't have to touch your router at all.
  • Strengthens Wi-Fi connection with Dual Bands
    Stream movies, play games online, and browse the Web without interruptions thanks to quick data transfer speeds of up to N300 + AC867 Mbps. The range extender features dual bands and can also focus the Wi-Fi signal directly to your connected devices for optimal performance, thanks to Beamforming technology.
  • Cross band technology maximizes Wi-Fi
    Cross band technology allows information to be obtained on one band and transmitted on the other, resulting in reduced dropped data packets, faster media transfer speeds, and a stronger, more consistent signal throughout your home.
  • Wired connection with Gigabit Ethernet port
    Connect a wired device such as a gaming console, Blu-ray player, Smart TV, or streaming player to your Wi-Fi network. The extender's Gigabit Ethernet port provides data transfer speeds 10x faster than a Fast Ethernet port.
Linksys RE6400 - Wi-Fi range extender
External
IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
8.7 cm x 12.1 cm x 6 cm
1-year warranty
8.7 cm
12.1 cm
6 cm
External
Wireless
IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Protected Setup (WPS), Cross-Band Technology, Spot Finder Technology, beamforming technology
Encryption Algorithm
WPA, WPA2, 128-bit AES
IEEE 802.11ac
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 1000Base-T - RJ-45
Limited warranty - 1 year , Technical support - 90 days
C0HL C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
C0HL C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
C0HL C2G 2m Cat6a Shielded Patch - Blue In Stock £7.05
Speed: 1200Mbps
Brand: Linksys
Price Range Ex VAT: 50 - 100
