Lindy Generic Lindy 2 Port VGA Splitter Pro
Quicklinx: 82VQWS00 Mfr#: 32569
LINDY 2 Port VGA Splitter PRO 350Mhz
Duplicate and amplify your PC's video signals for transmission to dual monitors!
This compact video splitter is a very effective solution for users who need to distribute multiple video signals over long distances. It supports high resolution VGA signals of up to 2048 x 1536 (QXGA) and, when using LINDY Premium Gold cables, distances of up to 55m.
Duplicates the video signal from your PC to 2 CRT or LCD monitors
Provides a simultaneous display on all connected monitors
Enhances video signals for long distance broadcasting (up to 55m)
Maximum Resolution: 2048 x 1536
Power supply included
Specification
Product Description LINDY 2 Port VGA Splitter PRO 350Mhz
Device Type VGA Splitter
Resolution Maximum Resolution 2048 x 1536
Bandwidth 350MHz for each port
Connectors 15 Way HD Male (input) and 15 Way HD Female (output)
Compatibility Can be used with CRT and LCD/TFT displays
Dimensions (WxDxH) 127 x 41 x 27mm
Lindy 2 Port VGA Splitter Pro - video splitter - 2 ports
Video splitter - 2 ports - cascadable
12.7 cm x 4.1 cm x 2.7 cm
Enclosure Type
Desktop
Max Resolution
2048 x 1536
Max Video Bandwidth
350 MHz
2 x VGA output HD-15 , 1 x VGA HD-15
External power adapter
12.7 cm
4.1 cm
2.7 cm
