Your basket is empty
LightwaveRF Lighting 1 Gang Wire-free Switch White Plastic
Quicklinx: 9YKDWS00 Mfr#: JSJSLW205
Create an atmousphere with the LightwaveRF White Plastic 1 Gang Wireless On/Off Dimmer
Battery powered 1 gang dimmer that wirelessly controls LightwaveRF devices and lamps
The1 gang dimmer switches can be installed on any flat surface
Battery operated and not connected to your mains wiring so can be placed anywhere you wish
This can be controlled by PC or smartphone when used with the WIFI link controller
3V CR2032 lithium battery included
No wiring required 433.9 Mhz
Surface mounted
Download LightwaverRF APP from your APP store
White Plastic finish
