LightwaveRF Gen 2 Smart Socket 2 Gang - White
Quicklinx: DL9JWS00 Mfr#: L42WH
Colours:
L42 - Smart Socket (2 gang)
Bring your home to life. Beautifully designed smart sockets to help control your appliances from wherever you are.
Begin your home automation adventure by using our stylish smart socket to control your lamps, appliances, and more. This model incorporates all the great features from our Generation 1 products and adds Apple HomeKit compatibility, 2-way communication, built-in energy monitoring, and more! This socket is quick and easy to DIY install. Available in Stainless Steel and White Metal finishes, and includes an optional 10mm spacer.
HomeKit Control
Lightwave’s remote socket seamlessly integrates with Apple HomeKit, so you can control your home and make optimal use of smart devices from your smartphone or tablet, from wherever you are.
Wireless socket
A contemporary stainless steel or white metal finish and fully 3000W rated like any other 1 gang or 2 gang socket; however, you can control a Lightwave smart socket from your smartphone.
Feature rich
Our second generation smart socket enables real-time status updates of any connected appliances and built-in energy monitoring. All Lightwave sockets are also lockable to ensure family safety.
Simple installation
Standard wiring configurations make our smart wifi socket easy to DIY install or via a suitably qualified electrician. A 10mm spacer is included for shallower back boxes.
Generation 2 device
Requires Link Plus and Link Plus App for operation
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT
DIY retrofit
All Lightwave devices are safe and legal to DIY retrofit in your own home
  • Schedule appliances
    Cooking? Working? Want to switch the kettle on from the comfort of your sofa? Use a Lightwave smart socket to create the perfect atmosphere in your living space, however you want your home to feel at any given moment.
  • Stay secure
    Away from home? Set schedules for a smart plug-in socket to switch the radio or TV on, or use smart sockets to switch lamps on at certain times to simulate occupancy. Lightwave helps you to control your appliances wherever you are.
LightwaveRF L42 Smart Socket (2 gang) - 2nd Generation - smart plug - metal white
Smart plug
Functions
Energy use monitor
Internet of Things (IoT) Platform
Apple HomeKit
Intelligent Assistant
Google Assistant, Alexa
Wireless
Metal white
15 cm x 3 cm x 8.8 cm
Smart plug
Functions
Energy use monitor
Wireless
Platform
Apple HomeKit
Compatible Services
IFTTT
Metal white
Nominal Voltage
AC 230V
Power Provided
3000 Watt
Warranty
15 cm
3 cm
8.8 cm
132 g
