LIFX Z Colour and White Wi-Fi Smart LED Light Strip  - 2 Meters
Quicklinx: DDB9WS00 Mfr#: LZHC2M4INUC07
Type: Light strip kit
Compatible With: Alexa, Google Assistant
£74.99 ex VAT
£89.98 inc VAT
LIFX Z is the lighting strip that uses Wi-Fi to create the perfect light for you at any moment. A simple-to-use app allows you to fine tune your lighting experience; control your entire strip, or select colors for addressable zones - the choice is yours.
  • Everything you need
    With all the intelligence built into the light, it is easy to kick start your connected home. No technical skills or additional hardware needed.
  • Seriously simple
    No need for a hub or messy hardware. Just plug in, download and play! You can expand with LIFX at any time and unlock more features.
LIFX Z Starter Kit with HomeKit - light strip kit - LED
Light strip kit
Light Source Type
LED
Dimmer
Translucent
Wattage
17 W
Colour of Illumination
16 million colours
Luminous Power
1400 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa
Platform
Apple HomeKit, Google Home
Communications Technology
Wi-Fi
AC 100 - 240 V
Frequency Required
50/60 Hz
Light strip kit
Dimmer
Self-adhesive, indoor usage, iOS compatible, Wi-Fi controlled, interconnectable, Windows compatible, interchangeable plug types A, C, G, I
Light Source
LED
Built-in LED Lamp
Wattage
17 W
16 million colours
Luminous Power
1400 lumens
Dimmable
1%-100% dimmable
Power Requirements
AC 100 - 240 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Platform
Wi-Fi
Product Material
Plastic
Body Colour
Translucent
Power adapter, LED controller, 2 light strips (1 m)
UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
Warranty
2 years
12 mm
4 mm
Length
2 m
Brand: LIFX
Price Range Ex VAT: 50 - 100
