The Lightbulb Reinvented
LIFX is a smart lightbulb that uses Wi-Fi to bring immersive colour to your home. A simple-to-use app allows you to fine tune your lighting experience; control a single light or your entire home and enjoy strong vibrant colours along with delicate whites.
Easy Set Up
LIFX installs like any traditional light bulb. Simply download the app, connect to Wi-Fi and you're ready to go. No hub required Take complete control of your lighting. The free LIFX app is available on Android and iOS. With a few taps on your tablet, phone or watch, colours go from bright and vibrant to pure whites in seconds Get the most out of your LIFX by connecting with the rest of your smart home. LiFX works other Smart Products including Amazon Echo, Nest Thermostat and Protect, Logitech Pop and many more Intuitive Control - Control lights individually, select beautiful themes and scenes, create custom groupings to easily control multiple bulbs at the same time
- 16 million colours and warm to cool whites
- Works with Alexa for voice control
- Easy to set up, built in Wi-Fi - NO HUB REQUIRED
A Connected Home Should Be Easy
LIFX lights are engineered to provide a simple way to start designing your connected home. A single bulb contains all the technology and hardware needed to use your lights. LIFX is ready to seamlessly integrate with some of your favourite smart home products, including Amazon Echo, Nest and SmartThings.
Highlights
- Easy set-up, no extra hardware.
- Bold, room-filling colour.
- Lasts up to 22 years*.
- One app for Android, iOS and Windows 10.
- Based on 3 hours use per day.
Experience Light Differently
One App, Your Device
Take complete control of your lighting. The free LIFX app is available on Android, iOS and Windows 10. With a few taps on your tablet, phone or watch, colours go from bright and vibrant to pure whites in seconds.
Seriously Simple
With all the intelligence built into the bulb it is easy to kick start your connected home. No technical skills or additional hardware needed. Regular software updates and cutting-edge integrations mean LIFX bulbs only improve over time.
In Tune with Your Needs
LIFX works to make connected living simple by responding to you. Arrive home and have your lights come on automatically or take control from your couch, bed or even work, the LIFX app lets you immerse your home in light, your way.
Even Better Together
Get the full experience when you expand LIFX to your entire home. Immerse yourself in ready-made colour palettes or create and save your own with scenes. Group your lights to control rooms or your entire home with just an easy tap on your LIFX app.
Plug in
Replace your current lightbulb with a LIFX bulb.
Download
Download the free LIFX app available for iOS, Android and Windows 10.
Play
Explore bold colours, intense themes and create lighting schedules.
Expand
Add more LIFX bulbs whenever you want and unlock more features.
The Connected Home, Made Simple.
LIFX bulbs combine built in features and intuitive integrations to make building your smart home easy. Connect your lights seamlessly with the likes of Amazon Echo, IFTTT, SmartThings and Nest.
- LIFX - LED light bulb
- Light Bulb Type
- LED light bulb
- Pearl white
- Shape
- A19
- Socket Type
- E27
- Wattage
- 11 W
- Wattage Equivalent
- 75 W
- Light Bulb Energy Efficiency Class
- A+
- Colour of Illumination
- Colour Temperature
- 2500-9000 K
- Luminous Power
- 1100 lumens
- Beam Angle
- 135 degree(s)
- Dimmable
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
- Environmentally friendly, Wi-Fi controlled
Light Bulb
- LED light bulb
- Shape
- A19
- Socket Type
- E27
- Wattage
- 11 W
- 75 W
- A+
- 2500-9000 K
- Luminous Power
- 1100 lumens
- Beam Angle
- 135 degree(s)
- Dimmable
- Lifetime
- 22.8 years
- 1%-100% dimmable, Android compatible, iOS compatible, Windows Mobile compatible, remote controlled
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50/60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Internet of Things (IoT) Hub
- Not needed
- Platform
- LIFX
- Communications Type
- Product-to-product
- Communications Technology
- WiFi
- Intelligent Assistant Compatible
- Google Assistant, Alexa
- Compatible Services
- IFTTT
- Body Colour
- Pearl white
- MIC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
- Warranty
- 2 years
- Diameter
- 63 mm
- Length
- 115 mm
- 210 g
