LIFX Mini White Wi-Fi Smart LED Light Bulb B22
Quicklinx: DDB3WS00 Mfr#: L3A19MW08B22
Type: Light bulb
Compatible With: Alexa, Apple Homekit, Google Assistant, Nest
Select:
More than 50 in stock
£20.83 ex VAT
£24.99 inc VAT
No colors or frills, just good old-fashioned illumination at your command. This Wi-Fi smart light is perfect for easy, affordable smart lighting in home or work.
  • Unanimously the perfect temperature of white for everywhere
  • Control from anywhere using the LIFX cloud technology
  • Dim with software and set the mood for any occasion
  • Connect your LIFX Mini White with leading connected home devices for further automation
  • Easy set up
    LIFX screws in like any traditional light bulb. Simply download the app, connect to Wi-Fi and you're ready to go.
  • Built in Wi-Fi & LIFX Cloud
    Offers full lighting control via Wi-Fi with the LIFX iOS, Android and Windows 10 apps. Access your bulbs anywhere, anytime via the cloud.
  • Adjustable and dimmable
    Connected lighting for your space, time of day, and mood. Choose from 16 million colors and a full range of warm to cool white with flexibility to dim. Experience how subtle adjustments in tone and brightness can enhance the comfort of any room.
  • Intuitive control
    Control lights individually or as groups, set timers, pick from beautiful themes or create your own custom scenes.
  • Bright & efficient
    LIFX Mini has an output of 800 lumens, the equivalent of a 60W traditional incandescent bulb with the benefit of only 9W energy use. Designed for Energy Star.
LIFX Mini White - LED light bulb
Light Source Type
LED light bulb
Pearl white
Shape
A19
Socket Type
B22
Wattage
9 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
250 degree(s)
Dimmable
AC 100 - 240 V
Frequency Required
50/60 Hz
Voice activated, Wi-Fi controlled
Light Source
LED light bulb
Shape
A19
Socket Type
B22
Wattage
9 W
A+
Energy Consumption per 1000h
9 kWh
Warm white light
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
250 degree(s)
Dimmable
Lifetime
22.8 years
1%-100% dimmable, Android compatible, iOS compatible, Windows compatible
Power Requirements
AC 100 - 240 V
Frequency Required
50/60 Hz
Body Colour
Pearl white
UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
ENERGY STAR
Warranty
2 years
Diameter
59 mm
Length
105 mm
141 g
63 mm x 63 mm x 125 mm / 177 g
Type: Light bulb
Compatible With: Apple Homekit
Compatible With: Nest
Brand: LIFX
Price Range Ex VAT: 0 - 50
