LIFX Mini Colour and White Wif-Fi Smart LED Light Bulb B22
Quicklinx: DDB7WS00 Mfr#: L3A19MC08B22
Type: Light bulb
Compatible With: Alexa, Apple Homekit, Google Assistant, Nest
£37.49 ex VAT
£44.98 inc VAT
The LIFX Mini is our most compact light yet, bringing vivid color, soft whites and more control to your home via your Wi-Fi.
  • Transform your space with over 16 million colors packed into a compact new light
  • Light your room with the perfect white, selecting from thousands of possibilities
  • Use Day & Dusk Mode to turn your lights on and off to suit your lifestyle
  • Connect your LIFX Mini with leading connected home devices for further automation
  • Easy set up
    LIFX screws in like any traditional light bulb. Simply download the app, connect to Wi-Fi and you're ready to go.
  • Built in Wi-Fi & LIFX Cloud
    Offers full lighting control via Wi-Fi with the LIFX iOS, Android and Windows 10 apps. Access your bulbs anywhere, anytime via the cloud.
  • Adjustable and dimmable
    Connected lighting for your space, time of day, and mood. Choose from 16 million colors and a full range of warm to cool white with flexibility to dim. Experience how subtle adjustments in tone and brightness can enhance the comfort of any room.
  • Intuitive control
    Control lights individually or as groups, set timers, pick from beautiful themes or create your own custom scenes.
  • Bright & efficient
    LIFX Mini has an output of 800 lumens, the equivalent of a 60W traditional incandescent bulb with the benefit of only 9W energy use. Designed for Energy Star.
LIFX Mini Colour - LED light bulb
Light Bulb Type
LED light bulb
Pearl white
Shape
A19
Socket Type
B22
Wattage
9 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
16 million colours
Colour Temperature
2500-9000 K
Luminous Power
800 lumens
Beam Angle
250 degree(s)
Dimmable
AC 100 - 240 V
Frequency Required
50/60 Hz
Voice activated, Wi-Fi controlled
Light Bulb
LED light bulb
Shape
A19
Socket Type
B22
Wattage
9 W
A+
Energy Consumption per 1000h
9 kWh
16 million colours
Colour Temperature
2500-9000 K
Luminous Power
800 lumens
Beam Angle
250 degree(s)
Dimmable
Lifetime
25000 hours
1%-100% dimmable, Android compatible, iOS compatible, Windows compatible
Power Requirements
AC 100 - 240 V
Frequency Required
50/60 Hz
Body Colour
Pearl white
Package
Box
UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
ENERGY STAR
Warranty
2 years
Diameter
60 mm
Length
105 mm
144 g
63 mm x 63 mm x 125 mm / 180 g
Type: Light bulb
Compatible With: Apple Homekit
Compatible With: Nest
Brand: LIFX
Price Range Ex VAT: 0 - 50
