LIFX Colour and White GU10 Wi-Fi Smart LED Light Bulb
Quicklinx: DDB8WS00 Mfr#: L3GU10C04
Type: Light bulb
Compatible With: Alexa, Google Assistant
Select:
15 in stock
£49.99 ex VAT
£59.98 inc VAT
Introducing the all new LIFX GU10 Downlight. Our most compact light yet, giving you vivid colours and tunable warm to cool whites everywhere in your home. This little number packs a real punch with 400 lumens from just 6 watts.
  • Create on/off schedules to automate your lighting to suit your lifestyle
  • Save energy with 400 lumens of light from just 6 watts
  • Set the mood. Movie nights, dinner parties are better with color
  • Connect your lights with your Google Home or Amazon Alexa for voice control
LIFX - LED light bulb with reflector
Light Bulb Type
Pearl white
Socket Type
GU10
Wattage
6 W
Colour of Illumination
16 million colours
Colour Temperature
2500-9000 K
Luminous Power
400 lumens
Beam Angle
60 degree(s)
Dimmable
AC 100 - 240 V
Frequency Required
50/60 Hz
Wi-Fi controlled
Light Bulb
Socket Type
GU10
Wattage
6 W
16 million colours
Colour Temperature
2500-9000 K
Luminous Power
400 lumens
Beam Angle
60 degree(s)
Dimmable
1%-100% dimmable, Android compatible, iOS compatible, Windows compatible
Power Requirements
AC 100 - 240 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Platform
Apple HomeKit
Intelligent Assistant Compatible
Google Assistant, Alexa
Body Colour
Pearl white
MIC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
Warranty
2 years
Diameter
50 mm
Length
72 mm
95 g
51 mm x 51 mm x 93 mm / 122.5 g
Type: Light bulb
Brand: LIFX
Price Range Ex VAT: 0 - 50
