LIFX Colour and White GU10 Wi-Fi Smart LED Light Bulb
Quicklinx: DDB8WS00 Mfr#: L3GU10C04
Select:
  • GU10
Introducing the all new LIFX GU10 Downlight. Our most compact light yet, giving you vivid colours and tunable warm to cool whites everywhere in your home. This little number packs a real punch with 400 lumens from just 6 watts.
  • Create on/off schedules to automate your lighting to suit your lifestyle
  • Save energy with 400 lumens of light from just 6 watts
  • Set the mood. Movie nights, dinner parties are better with color
  • Connect your lights with your Google Home or Amazon Alexa for voice control
LIFX - LED spot light bulb - GU10 - 6 W - 16 million colours - 2500-9000 K - pearl white
Light Source Type
LED spot light bulb
Pearl white
Socket Type
GU10
Wattage
6 W
Energy Efficiency Class
G
Colour of Illumination
16 million colours
Colour Temperature
2500-9000 K
Luminous Power
400 lumens
Beam Angle
60 degree(s)
Dimmable
Intelligent Assistant
Siri, Cortana, Google Assistant, Alexa
AC 100 - 240 V
Frequency Required
50/60 Hz
Light Source
LED spot light bulb
Socket Type
GU10
Wattage
6 W
G
Energy Consumption per 1000h
6 kWh
16 million colours
Colour Temperature
2500-9000 K
Luminous Power
400 lumens
Beam Angle
60 degree(s)
Dimmable
1%-100% dimmable, Android compatible, iOS compatible, Windows compatible, Wi-Fi controlled
Power Requirements
AC 100 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Body Colour
Pearl white
MIC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
Warranty
2 years
73 mm
Diameter
50 mm
96 g
51 mm x 51 mm x 93 mm / 126 g
