The Light Bulb Reinvented
LIFX + is a smart light bulb that uses Wi-Fi to customize and control your lighting via our simple to use app. Enjoy access to incredible colours and soft shades of white light, plus invisible infrared light to help security cameras see in the dark when the sun goes down. It’s business and play all rolled into the one cutting edge light.
Easy Set Up
LIFX installs like any traditional light bulb. Simply download the app, connect to Wi-Fi and you're ready to go. No hub required Take complete control of your lighting. The free LIFX app is available on Android and iOS. With a few taps on your tablet, phone or watch, colours go from bright and vibrant to pure whites in seconds Get the most out of your LIFX by connecting with the rest of your smart home. LiFX works other Smart Products including Amazon Echo, Nest Thermostat and Protect, Logitech Pop and many more. Intuitive Control - Control lights individually, select beautiful themes and scenes, create custom groupings to easily control multiple bulbs at the same time
- 16 million colours and warm to cool whites
- Works with Alexa for voice control
- Easy to set up, built in Wi-Fi - NO HUB REQUIRED
A Connected Home Should Be Easy
LIFX lights are engineered to provide a simple way to start designing your connected home. A single bulb contains all the technology and hardware needed to use your lights.
Highlights
- Night vision enhancement for cameras
- Easy set-up, no extra hardware
- Incredible colour, millions of possibilities.
- Warm and cool white range.
- Lasts up to 22.8 years*
- One app for Android, iOS & Windows 10
Lighting on Another Wavelength
Step up your connected home game and introduce infrared lighting to your space. The LIFX + uses infrared technology to bring security enhancements to your space, plus all of that you expect from LIFX packed into one bulb.
Power up your camera by furthering its vision down the hall, through the windows or across the room - the walls are your only limit.
Easy
The LIFX+ will work with your existing cameras to dramatically improve night vision. No security yet? There are lots of great camera options available to help you keep an eye on everything when you need it most.
One App, Your Device
Take complete control of your lighting. The free LIFX app is available on Android, iOS and Windows 10. With a few taps on your tablet, phone or watch, colours go from bright and vibrant to pure whites in seconds.
Seriously Simple
With all the intelligence built into the bulb it is easy to kick start your connected home. No technical skills or additional hardware needed. Regular software updates and cutting-edge integrations mean LIFX bulbs only improve over time.
In Tune with Your Needs
LIFX works to make connected living simple by responding to you. Arrive home and have your lights come on automatically or take control from your couch, bed or even work, the LIFX app lets you immerse your home in light, your way.
Invisible Light
The LIFX + adds night vision by emitting infrared light at a wavelength of 970mm. Especially selected by our engineers to ensure that the IR is completely invisible to the naked eye at night, yet the ideal companion for your smart cam.
Plug In
Replace your current lightbulb with a LIFX bulb.
Download
Download the free LIFX app available for iOS, Android and Windows 10.
Play
Explore bold colours, intense themes and create lighting schedules.
Expand
Add more LIFX bulbs whenever you want and unlock more features.
The Connected Home Made Simple
LIFX + works with Nest Cam and Arlo cameras to extend your night vision from down the hall to the darkest corners, plus it connects with many more partner products to make integrating your smart home easy.
Infrared night vision
LIFX + emits an infrared light invisible to the human eye, yet crystal clear for your camera. -
Control over 16 million vivid colors
LIFX Color lighting produces extremely vivid, saturated and powerful colors with over 16 million to choose from. -
Day & dusk automation
Automate your lighting to suit your daily schedule. Wake up with your lights fading on, or be greeted to a home filled with light.
- LIFX - LED light bulb - shape: A19 - B22 - 11 W - 16 million colours - 2500-9000 K - pearl white
- Light Source Type
- LED light bulb
- Pearl white
- Shape
- A19
- Socket Type
- B22
- Wattage
- 11 W
- Wattage Equivalent
- 75 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Colour Temperature
- 2500-9000 K
- Luminous Power
- 1100 lumens
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa
- Platform
- Nest, SmartThings, LIFX
- Voltage Required
- AC 110 - 240 V
- Frequency Required
- 50/60 Hz
Light Source
- LED light bulb
- Shape
- A19
- Socket Type
- B22
- Wattage
- 11 W
- 75 W
- A+
- 2500-9000 K
- Luminous Power
- 1100 lumens
- Dimmable
- Android compatible, iOS compatible, infrared night vision, controlled via Wi-Fi, Windows compatible
Power Requirements
- Voltage Required
- AC 110 - 240 V
- 50/60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Platform
- Body Colour
- Pearl white
- UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
- Warranty
- 2 years
- 140 mm
- Diameter
- 70 mm
- 300 g
- Shipping Dimensions (WxDxH) / Weight
- 75 mm x 75 mm x 140 mm
