Liebert PSI XR 1500VA (1350W) 230V RACK/TOWER UPS
Quicklinx: 7GX1WS00 Mfr#: PS1500RT3-230XR
Type: UPS
Power Rating: 1350Watt
Hurry, only 1 left in stock!
£344.38 ex VAT
£413.25 inc VAT
Liebert PSI-XR 1500VA is a compact, line-interactive UPS system designed especially for IT applications such as network closets and small data centers. The flexible design of Liebert PSI-XR allows the unit to be configured as a self-standing tower or to be rack-mounted within a 2U space. It is available in four capacities.
Liebert PSI-XR PS1500RT3 - UPS - 1350 Watt - 1500 VA
UPS - external
Rack Size
2U
28 kg
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
1350 Watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
5 min at full load
Ethernet 10/100
Remote Management Protocol
SNMP
Microsoft Windows 2000 / XP, Apple MacOS X 10.2 or later
44 cm x 49.1 cm x 8.8 cm
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
Line interactive
Supported Battery Technology
Lead Acid
Input Voltage Range
AC 165 - 300 V
Frequency Provided
45 - 65 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 45 - 65 Hz
Power Capacity
1350 Watt / 1500 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
220 Joules
Circuit Protection
Circuit breaker
Lead Acid
Voltage Provided
12 V
Run Time (Up To)
5 min at full load
Recharge Time
5 hours
Remote Management Interface
Ethernet 10/100
SNMP
1 x management (USB) - 4 pin USB Type B , 2 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x LAN
Expansion Slots
Expansion Slot
2 x power cable - external , Serial cable - external - 1.8 m , USB cable - external - 1.8 m
Rack Mounting Kit
Included
Audible alarm, overload protection
IEC 62040-2 class B, IEC 62040-1-1, RoHS, WEEE
Software Included
Drivers & Utilities
0 - 90%
Sound Emission
40 dBA
44 cm
49.1 cm
8.8 cm
28 kg
Shipping Width
56 cm
Shipping Depth
61.2 cm
Shipping Height
22.8 cm
Shipping Weight
32 kg
Type: UPS
Brand: Liebert
Price Range Ex VAT: 300 - 500
