Liebert PSI 3000VA 2700W 230V RACK/TOWER UPS
Quicklinx: 7GX3WS00 Mfr#: PS3000RT3-230
Type: UPS
Power Rating: 2700Watt
Hurry, only 2 left in stock!
£657.26 ex VAT
£788.71 inc VAT
Express delivery Order within the next hour for delivery tomorrow
Liebert PSI 3000VA is a compact, line-interactive UPS system designed especially for IT applications such as network closets and small data centers. The flexible design of Liebert PSI allows the UPS to be configured as a self-standing tower or to be rack-mounted within a 2U space. It provides reliable power protection for servers, critical nodes, network workstations, large network peripherals, network routers, bridges, and other electronic equipment.
Liebert PSI PS2200RT3-230 - UPS - 2700 Watt - 3000 VA
UPS - external
Rack Size
2U
37.2 kg
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
2700 Watt / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid - 9 Ah
Battery Form Factor
Plug-in module
Batteries Qty
6
Run Time (Up To)
3 min at full load
RS-232, USB
Tower stand
44 cm x 65.7 cm x 8.8 cm
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage Range
AC 165 - 300 V
Frequency Provided
45 - 65 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 45 - 65 Hz
Power Capacity
2700 Watt / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
220 Joules
Circuit Protection
Circuit breaker
Quantity
6
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
3 min at full load , 3 min at 90% load , 4 min at 80% load , 5 min at 70% load , 7 min at 60% load , 9 min at half load , 12 min at 40% load , 17 min at 30% load , 32 min at 20% load , 76 min at 10% load
Recharge Time
5 hours
Remote Management Interface
RS-232, USB
1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Tower stand
USB cable - external , 2 x power cable - external
Rack Mounting Kit
Included
LED display, remote ON/OFF function, hot-swappable batteries
EN 61000-3-2, IEC 61000-3-2, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-6, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, IEC 62040-1-1, IEC 62040-2, RoHS, EN 62040-1-1, EN 62040-2
Software Included
Liebert MultiLink
0 - 90% (non-condensing)
Sound Emission
45 dBA
44 cm
65.7 cm
8.8 cm
37.2 kg
Shipping Width
56 cm
Shipping Depth
77.6 cm
Shipping Height
22.8 cm
Shipping Weight
41.5 kg
Type: UPS
Brand: Liebert
Price Range Ex VAT: 500 - 750
