Liebert PSI 1500VA (1350W) UPS
Quicklinx: 7BF4WS00 Mfr#: PS1500RT3-230
Type: UPS
Power Rating: 1350Watt
15 in stock
£337.70 ex VAT
£405.24 inc VAT
Liebert PSI 1500VA is a compact, line-interactive UPS system designed especially for IT applications such as network closets and small data centers. The flexible design of Liebert PSI allows the UPS to be configured as a self-standing tower or to be rack-mounted within a 2U space. It provides reliable power protection for servers, critical nodes, network workstations, large network peripherals, network routers, bridges, and other electronic equipment.
Liebert PSI PS1500RT3-230 - UPS - 1350 Watt - 1500 VA
UPS - Power Factor Correction (PFC) - rack-mountable / external
Rack Size
2U
20.9 kg
Input Wiring
1-phase
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
1350 Watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13 - 230 V
Lead Acid - 9 Ah
Battery Form Factor
Plug-in module
Batteries Qty
3
Run Time (Up To)
3 min at full load
RS-232, USB
Tower stand
44 cm x 41.2 cm x 8.8 cm
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 165 - 300 V
Frequency Provided
50/60 Hz
Input Wiring
1-phase
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 50/60 Hz
Power Capacity
1350 Watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
220 Joules
Circuit Protection
Circuit breaker
Power Factor (PF)
0.9
Quantity
3
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
3 min at full load , 3 min at 90% load , 4 min at 80% load , 5 min at 70% load , 7 min at 60% load , 9 min at half load , 12 min at 40% load , 17 min at 30% load , 32 min at 20% load , 76 min at 10% load
Recharge Time
5 hours
Switchover Time
4 ms
Sealed
Remote Management Interface
RS-232, USB
1 x USB 2.0 - 4 pin USB Type B , 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Tower stand
USB cable - external , 2 x power cable - external
Rack Mounting Kit
Included
LED display, overload protection, remote ON/OFF function, hot-swappable batteries, VRLA battery support, forced cooling
EN 61000-3-2, IEC 61000-3-2, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-6, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, IEC 62040-1-1, IEC 62040-2, RoHS, EN 62040-1-1, EN 62040-2, IP20
Software Included
Liebert MultiLink
0 - 90%
Sound Emission
45 dB
44 cm
41.2 cm
8.8 cm
20.9 kg
Shipping Width
56 cm
Shipping Depth
59.5 cm
Shipping Height
22.8 cm
Shipping Weight
24.1 kg
Type: UPS
Brand: Liebert
Price Range Ex VAT: 300 - 500
