A New Look for Balanced Sound
Simply Stylish
A sleek, rounded design with a rubberised finish is easy to hold and fits comfortably in your hand.
Experience the Sound of Excellence
LG XBOOM Go PL2 with Meridian technology gives you premium quality sound. Hear deep bass and rich tones, every time you play music.
Bring Music to Life
Sound Boost amplifies sound power and widens the sound field. Just press the button to lift the party atmosphere.
Weather-Proof Enjoyment
An IPX5 rating means your speaker can get wet and keep on working, so you can keep on dancing.
Play for Longer
A 10-hour battery life gives you the freedom to enjoy your music on-the-go without charging worries.
Multiply the Music
Wirelessly link two LG XBOOM Go PL2 to double the sound output. Bigger sound only means one thing — better parties and more fun.
Enjoy Music and More Just with Your Voice
Press the play button for two seconds, then speak to access Google Assistant on your Androidâ„¢ phone or Siri on iOS. You can play music, podcasts and more with a simple voice command.
Share Playlists with Multi Bluetooth
Pair two devices at the same time via the XBOOM App. Use any of the connected devices to seamlessly control a playlist with no interruption to music.
Answer Calls with Speaker Phone
LG XBOOM Go PL2 will automatically switch to an incoming call when music is playing, and you can easily share the call with friends.
Total Control with the XBOOM App
Control everything on one app. Get it on the Google Play Store.
A sleek, portable, powerful speaker
Take the party with you. Enjoy up to 10 hours of playback, IPX5 water resistance and high-quality AAC audio formats. Meridian technology combines with a passive radiator for rich sound even at the highest volume. Connecting is always easy with both Bluetooth and voice command capabilities. -
Exceptional audio on the go
Amp up the party with room-filling sound. Widen the sound field with Sound Boost EQ mode. LG teamed up with Meridian - the leader in high-resolution audio - for powerful bass and clear vocals with less distortion even at the highest volume. -
Powerful, portable audio
Bring big sound wherever you go. The small, sleek body of the LG XBOOM Go boasts 5 watts of power. With Meridian audio technology and a passive radiator, you get one powerful speaker that couldn't be easier to pack with you. -
Superior sound quality
Enjoy Advanced Audio Coding (AAC) with LG XBOOM Go. AAC is the default coding standard for lossy digital audio compression. It's supported by both iPhone and Android phones and generally achieves higher sound quality than MP3 at the same bit rate. -
Pool party-proof
Keep jamming without the worry of water hitting your speaker. The water-resistant LG XBOOM Go is a speaker built to play in less-than-perfect conditions. So the music never has to stop. -
All-day battery
Keep the hits coming all night long. Enjoy up to 10 hours of battery life for crystal-clear audio that keeps going as long as you do. -
Wireless Party Link
Get bigger sound for a bigger party. Wireless Party Link allows you to connect up to 100 LG speakers for one massive, immersive sound. -
Convenient voice command
Use the voice command hotkey to control what's playing on your XBOOM Go using just your voice. Simply activate your phone's voice assistant and you can tell your smartphone what to play - or skip or pause - without ever leaving the dancefloor. -
Pair two devices at the same time via the XBOOM App. Use any of the connected devices to seamlessly control a playlist with no interruption to music. -
Convenient USB-C charging
Keep the party going. The portable LG XBOOM Go speaker features long-lasting battery life and easy USB Type-C charging - so you never run out of juice and the party never has to stop. -
Turn your speaker into a speakerphone
It's easier than ever to share a conversation with friends. With LG XBOOM Go's Bluetooth. capability, you can answer calls with the touch of a button and turn your gathering into a group chat for those conversations that just have to be shared. -
Wireless Bluetooth control
Control your speaker from your mobile device. When you download the LG XBOOM Bluetooth app, you can manage the audio connection, lighting effects, playlists, equalizer and more with just a few clicks. So you never have to take a break from the dancefloor.
- LG XBOOM Go PL2 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Water-resistant
- Enclosure Design
- Passive radiator
- Speaker Type
- Active
- Nominal Output Power
- 5 Watt
- Amplifier
- Integrated
- Bluetooth
- Intelligent Assistant
- Siri, Google Assistant ready - indirect
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 12.6 cm x 8 cm x 8.2 cm
- 350 g
- 1-year warranty
- Product Type
- Wireless Party Link
- Hands-Free Function
- Microphone
- Protection
- Water-resistant
- Enclosure Design
- Passive radiator
- Design Features
- Tuned by Meridian
Speaker System
- Speaker Type
- Active
- 5 Watt
- Amplifier
- Integrated
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC
- Controls
- Power on/off, volume, play/pause, Bluetooth source
- App-Controlled
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Type
- Product-to-product
- Communications Technology
- Bluetooth
- Voice Control
- Indirect
Speaker System Details
- Driver Details
- Speaker: Passive Radiator , Speaker: full-range driver - 1.75"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , DC power input (USB Type-C)
- Included Accessories
- USB-C cable
- IPX5
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 1500 mAh
- Run Time (Up To)
- 10 hour(s)
- Recharge Time
- 4 hour(s)
- 12.6 cm
- 8 cm
- 8.2 cm
- 350 g
- Shipping Width
- 16 cm
- Shipping Depth
- 11.3 cm
- Shipping Height
- 13.4 cm
- Shipping Weight
- 660 g
- Limited warranty - parts and labour - 1 year
