Product
LG UM88 34" 3440x1440 5ms HDMI Display Port IPS Monitor
Quicklinx: C0MTWS00 Mfr#: 34UM88
Perfect for multitasking and entertaining, the LG 21:9 is always the right choice. This display enables you to stretch the limits of screen real-estate. With the IPS display, visual comfort is delivered, while ensuring vivid and accurate color expression.
  • Flawless color expression
    You are delivered an immersive artwork through a sRGB color space. Color accuracy is ensured via color calibration.
  • Advanced tech design
    The improved ergonomic stand can be installed quickly and easily without the need for tools, and its height and tilt are adjustable for your comfort.
  • Up-scaled work efficiency
    Screen split and PIP mode bring you to be the real multi-tasker.
  • USB 3.0 Quick Charge
    Charge the battery of a connected device quickly using the USB 3.0 port on the product.
  • Game mode
    Game mode, consisting of FPS, RTS, and custom modes, provides a customized gaming experience, that varies with genres.
  • Fully geared UP with winning features
    Black stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time.
LG 34UM88 - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
79 kWh
Power Consumption (On mode)
54 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms (On/Off); 5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xThunderbolt, 2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
82.99 cm x 25.24 cm x 42.89 cm
8.4 kg
FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0
Display Type
Energy Class
Class B
79 kWh
54 W
Diagonal Size
34"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, HDCP, Picture Mode, game mode, On-screen Digital Controls, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, PBP, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Color Calibration, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, FreeSync Technology, split screen 2.0, My Display Preset, Mega DFC, USB 3.0 Quick Charge, Dual EDID
82.99 cm x 25.24 cm x 42.89 cm - with stand
8.4 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x HDMI , 2 x Thunderbolt , DisplayPort , USB 3.0 upstream , Headphones , 2 x USB 3.0 downstream
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
Key lock
Cable holder
AC 120/230 V
70 Watt
Power Consumption Sleep
1.2 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 82.99 cm - depth: 25.24 cm - height: 42.89 cm - weight: 8.4 kg , Without stand - width: 82.99 cm - depth: 4.92 cm - height: 37.98 cm - weight: 6.3 kg
C0MT C2G HDMI to DisplayPort Adapter Converter In Stock £37.08
C0MT C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.43
C0MT C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.11
C0MT C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.05
C0MT C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.54
C0MT C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.74
