Perfect for multitasking and entertaining, the LG 21:9 is always the right choice. This display enables you to stretch the limits of screen real-estate. With the IPS display, visual comfort is delivered, while ensuring vivid and accurate color expression.
Flawless color expression
You are delivered an immersive artwork through a sRGB color space. Color accuracy is ensured via color calibration. -
Advanced tech design
The improved ergonomic stand can be installed quickly and easily without the need for tools, and its height and tilt are adjustable for your comfort. -
Up-scaled work efficiency
Screen split and PIP mode bring you to be the real multi-tasker. -
USB 3.0 Quick Charge
Charge the battery of a connected device quickly using the USB 3.0 port on the product. -
Game mode
Game mode, consisting of FPS, RTS, and custom modes, provides a customized gaming experience, that varies with genres. -
Fully geared UP with winning features
Black stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time.
- LG 34UM88 - LED monitor - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class B
- Energy Consumption per Year
- 79 kWh
- Power Consumption (On mode)
- 54 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey), 14 ms (On/Off)
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xThunderbolt, 2xHDMI, DisplayPort
- Height, tilt
- Voltage
- AC 120/230 V
- 82.99 cm x 25.24 cm x 42.89 cm
- 8.4 kg
- FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0
- Display Type
- Energy Class
- Class B
- 79 kWh
- Diagonal Size
- 34"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 61 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Picture in picture, HDCP, Picture Mode, game mode, On-screen Digital Controls, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, PBP, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Colour Calibration, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, split screen 2.0, My Display Preset, Mega DFC, USB 3.0 Quick Charge, Dual EDID
- 82.99 cm x 25.24 cm x 42.89 cm - with stand
- 8.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- 2 x HDMI , 2 x Thunderbolt , DisplayPort , USB 3.0 upstream , Headphones , 2 x USB 3.0 downstream
Mechanical
- Height, tilt
- Tilt Angle
- -5/+20
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Key lock
- Included Accessories
- Cable holder
- Input Voltage
- AC 120/230 V
- 54 W
- Power Consumption (Typical)
- 70 Watt
- Power Consumption Sleep
- 1.2 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 82.99 cm - depth: 25.24 cm - height: 42.89 cm - weight: 8.4 kg , Without stand - width: 82.99 cm - depth: 4.92 cm - height: 37.98 cm - weight: 6.3 kg
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
