Perfect for multitasking and entertaining, the LG 21:9 UltraWide™ is always the right choice. A full range of 21:9 UltraWide™ monitors, both curved and flat, are available to meet your needs.
21:9 UltraWide™ QHD on IPS Display
"21:9 UltraWide™ QHD (3440*1440) display offers visual comfort and ensures your best viewing pleasure. There is no color shift or no distortion of color at all."
The Beauty of ArcLine
Inspired by the beauty and power of nature, the ArcLine completes the design with a refined aesthetic flair.
The Big Convergence of FreeSync & 21:9 UltraWide™
The whole new FreeSync era has come. On the 34-inch 21:9 UltraWide™ QHD, you can experience the next level of gaming without any tearing and stuttering.
Game Mode
"Game Mode, consisting of FPS, RTS, and Custom modes, provides a customized gaming experience that varies with genres."
Fully Geared UP with Winning Features
Black Stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time.
Flawless Color Expression
You are guaranteed an immersive artwork through a sRGB over 99% color space.Color calibration tests are conducted on the production line to ensure color accuracy.
Advanced Tech Design
The newly designed ergonomic stand can be installed quickly and easily without the need for tools, and its height and tilt are adjustable for your comfort.
Up-scaled Work Efficiency
Screen Split and PIP Mode bring you to be the real multi-tasker.
Exceptional Usability
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
21:9 UltraWide Full HD IPS display
The UltraWide 21:9 aspect ratio makes games and movies more immersive than ever. The clarity of 1080p pixel Full HD resolution with IPS is a game-changer. Simply put, from any viewing angle, everything looks more crisp and detailed in Full HD. -
sRGB over 99%
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this monitor is a great solution for gamers, professional photographers, graphic designers or anyone looking for highly accurate color. -
On-Screen control
On-Screen control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor. -
Screen Split 2.0
Customize your monitor layout for multitasking with the latest version of LG Screen Split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices. -
FreeSync
LG's 21:9 UltraWide monitors with FreeSync technology eliminate the tearing and stuttering that have plagued gaming enthusiasts for years. -
Game mode
Dedicated game modes assure optimal viewing conditions. Included are a total of three different preset game modes: two first-person shooter modes plus a real-time strategy mode. Choose the right mode for the game you're playing. -
Advanced gaming features
Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action. -
Height&tilt adjustable stand
Select LG monitors are easy to put together with a simple press-and-click display-to-base attachment. The monitors provide comfortable viewing with versatile screen tilt/height adjustments. -
Arcline design
The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
- LG 34UM68-P - LED monitor - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class B
- Energy Consumption per Year
- 58 kWh
- Power Consumption (On mode)
- 40 W
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 2560 x 1080
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Gamut
- 99% Adobe RGB
- Input Connectors
- 2xHDMI, DisplayPort
- Voltage
- AC 120/230 V
- 82.99 cm x 25.24 cm x 42.89 cm
- 8 kg
- Plug and Play, DDC/CI
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 58 kWh
- Diagonal Size
- 34"
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 2560 x 1080
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Gamut
- 99% Adobe RGB
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- OSD Languages
- Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
- Split screen, Picture Mode, Auto Resolution, On-screen Digital Controls, Mercury free, MaxxAudio, Black Stabilizer
- 82.99 cm x 25.24 cm x 42.89 cm - with stand
- 8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- 2 x HDMI , DisplayPort , Headphones
Mechanical
- VESA Mounting Interface
- 75 x 75 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 40 W
- Power Consumption (Typical)
- 43 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 82.99 cm - depth: 25.24 cm - height: 42.89 cm - weight: 8 kg , Without stand - width: 82.99 cm - depth: 4.92 cm - height: 37.98 cm - weight: 6 kg
- Limited warranty - 3 years
