Your basket is empty
LG UM67 29" 2560x1080 5ms HDMI Display Port IPS Monitor
Quicklinx: C0MRWS00 Mfr#: 29UM68
Diagonal Size: 29in
Max Resolution: 2560 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
More than 50 in stock
£232.42 ex VAT
£278.90 inc VAT
21:9 UltraWide™ FHD on IPS Display
"21:9 UltraWide™ FHD (2560*1080) display offers visual comfort and ensures your best viewing pleasure. There is no color shift or no distortion of color at all."
The Beauty of ArcLine
Inspired by the beauty and power of nature, the ArcLine completes the design with a refined aesthetic flair.
UltraWide™ FOV Meets FreeSync
Experience fluid motion play on the 21:9 UltraWide™’s generous field of view without screen tearing or stuttering.
Game Mode
"Game Mode, consisting of FPS, RTS, and Custom modes, provides a customized gaming experience that varies with genres."
Fully Geared UP with Winning Features
Black Stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time.
Flawless Color Expression
"You are guaranteed an immersive artwork through a sRGB over 99% color space.Color calibration tests are conducted on the production line to ensure color accuracy. "
Up-scaled Work Efficiency
Screen Split and PIP Mode bring you to be the real multi-tasker.
Exceptional Usability
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
LG 29UM68-P - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32 W
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
2560 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Input Connectors
2xHDMI, DisplayPort
70.25 cm x 20.47 cm x 41.4 cm
5.4 kg
Plug and Play
Display Type
Energy Class
Class B
47 kWh
32 W
Diagonal Size
29"
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
2560 x 1080
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
Picture Mode, Auto Resolution, 99% Adobe RGB colour gamut, On-screen Digital Controls, 4-screen split, Mercury free, MaxxAudio, Black Stabilizer
70.25 cm x 20.47 cm x 41.4 cm - with stand
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI , DisplayPort , Headphones
Mechanical
Flat Panel Mount Interface
75 x 75 mm
Plug and Play
31 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 70.25 cm - depth: 20.47 cm - height: 41.4 cm - weight: 5.4 kg , Without stand - width: 70.25 cm - depth: 6.38 cm - height: 32.84 cm - weight: 4.8 kg
Diagonal Size: 29in
Response Time: 5ms
Interfaces: HDMI
Brand: LG
Price Range Ex VAT: 150 - 300
