LG UM57 25" 2560x1080 5ms HDMI IPS Monitor
Quicklinx: C0MPWS00 Mfr#: 25UM58
21:9 UltraWide™ QHD on IPS Display
21:9 UltraWide™ QHD (3440*1440) display offers visual comfort and ensures your best viewing pleasure. There is no color shift or no distortion of color at all.
Game Mode
Game Mode, consisting of FPS, RTS, and Custom modes, provides a customized gaming experience that varies with genres.
Fully Geared UP with Winning Features
Black Stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time.
sRGB over 99%
An immersive work environment is ensured through realistic color expression thanks to sRGB over 99 percent and the IPS display.
Up-scaled Work Efficiency
Screen Split and PIP Mode bring you to be the real multi-tasker.
Exceptional Usability
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
LG 25UM58-P - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class B
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Input Connectors
2xHDMI
60.9 cm x 18.8 cm x 38.3 cm
4 kg
Environmental Standards
TCO Certified Displays 7
Plug and Play, DDC/CI
3-year warranty
Display Type
Energy Class
Class B
38 kWh
26 W
Diagonal Size
25"
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
Split screen, Picture Mode, Auto Resolution, On-screen Digital Controls, CINEMA Screen Design, Dual Smart Solution, Black Stabilizer
60.9 cm x 18.8 cm x 38.3 cm - with stand
4 kg
2 x HDMI , Headphones
Mechanical
VESA Mounting Interface
75 x 75 mm
AC 120/230 V
24 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 60.9 cm - depth: 18.8 cm - height: 38.3 cm - weight: 4 kg , Without stand - width: 60.9 cm - depth: 5.5 cm - height: 28.7 cm - weight: 3.7 kg
TCO Certified
Limited warranty - 3 years
