21:9 UltraWide™ QHD on IPS Display
21:9 UltraWide™ QHD (3440*1440) display offers visual comfort and ensures your best viewing pleasure. There is no color shift or no distortion of color at all.
Game Mode
Game Mode, consisting of FPS, RTS, and Custom modes, provides a customized gaming experience that varies with genres.
Fully Geared UP with Winning Features
Black Stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time.
sRGB over 99%
An immersive work environment is ensured through realistic color expression thanks to sRGB over 99 percent and the IPS display.
Up-scaled Work Efficiency
Screen Split and PIP Mode bring you to be the real multi-tasker.
Exceptional Usability
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
- LG 25UM58-P - LED monitor - 25"
- LED-backlit LCD monitor - 25"
- Energy Class
- Class B
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 26 W
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 2560 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- 2xHDMI
- 60.9 cm x 18.8 cm x 38.3 cm
- 4 kg
- Plug and Play, DDC/CI
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 38 kWh
- Diagonal Size
- 25"
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 2560 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- OSD Languages
- Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
- Split screen, Picture Mode, Auto Resolution, On-screen Digital Controls, CINEMA Screen Design, Dual Smart Solution, Black Stabilizer
- 60.9 cm x 18.8 cm x 38.3 cm - with stand
- 4 kg
- 2 x HDMI , Headphones
Mechanical
- VESA Mounting Interface
- 75 x 75 mm
- Voltage Required
- AC 120/230 V
- 26 W
- 24 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 60.9 cm - depth: 18.8 cm - height: 38.3 cm - weight: 4 kg , Without stand - width: 60.9 cm - depth: 5.5 cm - height: 28.7 cm - weight: 3.7 kg
- Limited warranty - 3 years
