The LG Ultra HD IPS monitor offers both a larger workspace and accurate and detailed expression. In particular, the sRGB over 99% prevents gaps in color space, and the expression. The LG Ultra HD 4K monitor based on IPS offers accurate picture quality without any distortion and makes games as more realistic as possible. Finally, It brings to immersive gaming experience.
Edit perfect visual
The LG Ultra HD IPS monitor offers both a larger workspace and accurate and detailed expression. In particular, the sRGB over 99% prevents gaps in color space, and the expression. -
Realistic gaming experience
The LG Ultra HD 4K monitor based on IPS offers accurate picture quality without any distortion and makes games as more realistic as possible. Finally, It brings to immersive gaming experience. -
High-end gaming features
Black Stabilizer senses the darkest area and makes it brighter so that you can find enemies hiding in the shadows.And Dynamic Action Sync allows you to attack enemies faster with less lag time. -
Refined aesthetic design
The coexistence of smoothness and solidness in the curved structure. The beauty of ArcLine is the icing on the cake.
- LG 27UD68P - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 47 kWh
- Power Consumption (On mode)
- 32 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1554 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Gamut
- 99% Adobe RGB (CIE 1931)
- Input Connectors
- 2xHDMI, DisplayPort
- Height, pivot (rotation), tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- High glossy black, black colour with texture, silver frame, black hairline base
- 61.5 cm x 25.24 cm x 41.77 cm
- 6.7 kg
- Plug and Play, FCC Class B certified, UL, TUV, cUL, CB, DDC/CI, RoHS, REACH, KC, ERP, EPA
- Display Type
- Energy Class
- Class B
- 47 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1554 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 61 Hz
- Horizontal Refresh Rate
- 30 - 135 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- sRGB colour management, HDCP, SUPER + Resolution, Black eQualizer, On-screen Digital Controls, Flicker Safe, Reader Mode, SIX Axis Control, Mercury free, PBP, Factory Calibration, New CINEMA Screen Design, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Mega DFC
- 61.5 cm x 25.24 cm x 41.77 cm - with stand
- 6.7 kg
- 2 x HDMI , DisplayPort , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Input Voltage
- 32 W
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Windows 10
- Dimensions & Weight Details
- With stand - width: 61.5 cm - depth: 25.24 cm - height: 41.77 cm - weight: 6.7 kg , Without stand - width: 61.5 cm - depth: 3.93 cm - height: 36.51 cm - weight: 4.6 kg
