LG UD68P 27" 3840x2160 5ms HDMI Display Port 4K IPS Monitor
Quicklinx: C0MZWS00 Mfr#: 27UD68P
The LG Ultra HD IPS monitor offers both a larger workspace and accurate and detailed expression. In particular, the sRGB over 99% prevents gaps in color space, and the expression. The LG Ultra HD 4K monitor based on IPS offers accurate picture quality without any distortion and makes games as more realistic as possible. Finally, It brings to immersive gaming experience.
  • Edit perfect visual
  • Realistic gaming experience
  • High-end gaming features
    Black Stabilizer senses the darkest area and makes it brighter so that you can find enemies hiding in the shadows.And Dynamic Action Sync allows you to attack enemies faster with less lag time.
  • Refined aesthetic design
    The coexistence of smoothness and solidness in the curved structure. The beauty of ArcLine is the icing on the cake.
LG 27UD68P - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Pixel Pitch
0.1554 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating
High glossy black, black colour with texture, silver frame, black hairline base
61.5 cm x 25.24 cm x 41.77 cm
6.7 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, CB, DDC/CI, RoHS, REACH, KC, ERP, EPA
Display Type
Energy Class
Class B
47 kWh
32 W
Diagonal Size
27"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
sRGB colour management, HDCP, SUPER + Resolution, Black eQualizer, On-screen Digital Controls, Flicker Safe, Reader Mode, SIX Axis Control, Mercury free, PBP, Factory Calibration, New CINEMA Screen Design, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), 99% Adobe RGB (CIE 1931) colour gamut, Mega DFC
61.5 cm x 25.24 cm x 41.77 cm - with stand
6.7 kg
2 x HDMI , DisplayPort , Headphones
Mechanical
Tilt Angle
-5/+20
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Stand
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 61.5 cm - depth: 25.24 cm - height: 41.77 cm - weight: 6.7 kg , Without stand - width: 61.5 cm - depth: 3.93 cm - height: 36.51 cm - weight: 4.6 kg
