Perfect for multitasking and entertaining, the LG 21:9 UltraWide is always the right choice.
21:9 Curved UltraWide QHD on IPS display
21:9 Curved UltraWide QHD (3440 1440) display offers wrap-around field of view on a wide screen real estate. With IPS display, visual comfort is guaranteed while ensuring vivid and accurate color expression. -
Thunderbolt 2 compatibility with Mac devices
With the Thunderbolt 2 port for Mac devices, you can take advantage of data transmission that is 4 times faster than the USB 3.0, and also can expand computing capability more easily via a simple daisy-chain con?guration without the need for an extra connector. -
The beauty of ArcLine
Inspired by the beauty and power of nature, the ArcLine completes the design with a refined aesthetic flair. -
Flawless color expression
You are guaranteed an immersive artwork through a sRGB over 99% color space.Color calibration tests are conducted on the production line to ensure color accuracy. -
Amazing tech design
The amazingly designed ergonomic stand can be installed quickly and easily without the need for tools, and its height and tilt are adjustable for your comfort. -
USB 3.0 quick charge
Charge the battery of a connected device quickly using the USB 3.0 port on the product. -
Game Mode
Game Mode, consisting of FPS, RTS, and Custom modes, provides a customized gaming experience that varies with genres.
- LG 34UC98 - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class B
- Energy Consumption per Year
- 79 kWh
- Power Consumption (On mode)
- 54 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- QHD 3440 x 1440
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey), 14 ms (On/Off)
- Colour Support
- 1.074 billion colours (10-bit)
- Colour Gamut
- 99% Adobe RGB (CIE 1931)
- Input Connectors
- 2xThunderbolt, 2xHDMI, DisplayPort
- Height, tilt
- Voltage
- AC 120/230 V
- 81.76 cm x 23.04 cm x 45.14 cm
- 7.8 kg
- FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0, EDID compatible
- Display Type
- Energy Class
- Class B
- 79 kWh
- Diagonal Size
- 34"
- Curved Screen
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- QHD 3440 x 1440
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 61 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, Picture Mode, game mode, On-screen Digital Controls, FPS Mode, Flicker Safe, Reader Mode, SIX Axis Control, PBP, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, split screen 2.0, My Display Preset, Auto Power Off, Color Weakness Mode, Mega DFC, USB 3.0 Quick Charge
- 81.76 cm x 23.04 cm x 45.14 cm - with stand
- 7.8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- 2 x Thunderbolt , 2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- Height, tilt
- Tilt Angle
- -5/+15
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Key lock
- Included Accessories
- Stand
- Input Voltage
- AC 120/230 V
- 54 W
- Power Consumption (Typical)
- 70 Watt
- Power Consumption Sleep
- 1.2 Watt
- OS Required
- Microsoft Windows
- Dimensions & Weight Details
- With stand - width: 81.76 cm - depth: 23.04 cm - height: 45.14 cm - weight: 7.8 kg , Without stand - width: 81.76 cm - depth: 8.87 cm - height: 36.08 cm - weight: 6.2 kg
