LG SJ7 Modular Detachable Soundbar
Quicklinx: DJ0XWS00 Mfr#: SJ7
£374.17 ex VAT
£449.00 inc VAT
Different rooms have different needs, so the dual-speaker design of the LG Sound Bar Flex enables it to be configured in a variety of ways. However you like to enjoy movies and music, this audio package delivers. For maximum enjoyment of various types of programming (movies, sports, games, etc.), LG-exclusive Adaptive Sound Control can automatically detect what's playing and then enhance the clarity and impact of the audio. An outboard wireless subwoofer can drastically improve the cinematic audio experience, adding room-shaking bass to movies and more.
Enhance the home cinema experience without the clutter of unnecessary cables. LG Sound Sync technology links compatible LG televisions to the sound bar wirelessly, using Bluetooth. For even greater versatility, one of the speakers in this LG sound system is Bluetooth-enabled with its own built-in rechargeable battery, allowing it to be placed and enjoyed just about anywhere.
  • Flexible Design
  • Adaptive Sound Control
  • LG Sound Sync SJ7
  • Wireless Subwoofer
  • Bluetooth Connectivity
LG SJ7 Sound Bar Flex - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 4.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Amplifier
Integrated
Bluetooth
Audio Formats
PCM
Speaker System Details
1 x speaker 80 Watt - at 1 kHz - 8 Ohm , 1 x portable speaker 80 Watt - at 1 kHz - 8 Ohm , 1 x subwoofer 160 Watt 3 Ohm
Built-in Decoders
DTS Digital Surround, Dolby Audio
Sound Effects
Adaptive Sound Control (ASC), Bass Blast, Cinema
Speaker battery rechargeable - Lithium Ion
1-year warranty
Design Features
Transformable into a sound bar or rear/front speakers
Speaker System
System Components
Speaker Type
Active
Multiroom
Amplifier
Integrated
Sound Effects
Bluetooth 4.0
Built-in Decoders
Audio Formats
PCM
Additional Features
Speakers Included
1 x speaker - 80 Watt - at 1 kHz - 8 Ohm , 1 x portable speaker - 80 Watt - at 1 kHz - 8 Ohm - wireless , 1 x subwoofer - 160 Watt - 3 Ohm - wireless
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Digital audio input (optical) (TOS Link)
Remote control, speaker stands, audio (optical) cable
Power Source
AC power adapter, battery
Rechargeable - Lithium Ion
Run Time (Up To)
4 hour(s)
Dimensions (WxDxH) / Weight Details
Speaker: 34 cm x 11 cm x 7.4 cm , Portable speaker: 34 cm x 11 cm x 7.4 cm , Subwoofer: 17.1 cm x 25.2 cm x 32 cm
Limited warranty - parts and labour - 1 year
Brand: LG
Price Range Ex VAT: 300 - 500
