Product
LG SJ4 2.1 Channel 300W Soundbar with Wireless Sub
Quicklinx: F0KPWS00 Mfr#: SJ4
Audio System Type: Home theatre system
Surround system: 2.1 channel
Stock Status: Clearance
Hurry, only 2 left in stock!
£90.84 ex VAT
£109.00 inc VAT
Express delivery Order within the next 7 hours for delivery tomorrow
LG SJ4 Soundbar
Key Features:
High-Resolution Audio
Wireless Subwoofer
ASC (Adaptive Sound Control)
Auto Sound Engine
TV Matching Design
Bluetooth Stand-by
True to the Original High Resolution
A new standard of sound quality. With advanced audio processing technology delivering sound of 24bit/192kHz quality you have some of the best components available for Hi-Res Audio. Now you can listen to studio standards of sound with lossless playback, experiencing a new level of audio that is true to the original.
Wireless Subwoofer - Place your Bass Wirelessly
Free your living room from wires. LG’s active wireless subwoofer allows you to enjoy superb sound quality without compromising on design.
Adaptive Audio for what you watch
Intelligently adaptive audio. LG's unique audio enhancing technology analyses frequency levels as you listen to provide an optimum sound mix based on what you are watching. This advanced process ensures your audio instantly adapts to provide crystal clear dialogue or punchy powerful action whatever you choose to watch.
Optimised Audio
Automatically adjusted audio accuracy. LG Auto Sound Engine optimizes the audio at every volume level keeping the frequencies accurate in the right places. This delivers the correct sound balance no matter what volume your entertainment is playing at.
Bluetooth Stand-by, wake up your bar on demand
Sound starts the moment you transfer audio to the Soundbar. The Soundbar remains in sleep mode but turns on and begins playing when the audio is sent via Bluetooth.
Auto Music Play, music that follows you
Sound starts the moment you enter the room With Auto Music Play activated the bar can automatically take over the playback of the audio from a connected device the moment it sense the device is nearby.
Control with your TV Remote
LG Soundbar comes with a remote but you can choose to use your own TV remote as well. (LG, Sony, Philips, Sharp, Panasonic, Vizio, Toshiba and Samsung brand remotes).
Connected to your entertainment
Feel free to connect to the device you wish with HDMI, USB, Optical, Portable In and Bluetooth connectivity.
  • High-resolution audio
    With advanced audio processing technology delivering sound of 24 bit / 192 kHz quality you have excellent components. Now you can listen to studio standards of sound with lossless playback, experiencing a high level of audio that is true to the original.
  • Wireless subwoofer
    Free your living room from wires. LG's active wireless subwoofer allows you to enjoy superb sound quality without compromising on design.
  • Adaptive sound control
    LG's unique audio enhancing technology analyzes frequency levels as you listen to provide an optimum sound mix based on what you are watching. This advanced process ensures your audio instantly adapts to provide crystal clear dialog or punchy powerful action whatever you choose to watch.
  • Auto Sound Engine
  • Bluetooth Stand-by, wake up your bar on demand
    Sound starts the moment you transfer audio to the soundbar. The soundbar remains in sleep mode but turns on and begins playing when the audio is sent via Bluetooth.
  • Auto Music Play, music that follows you
LG SJ4 - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 2.1-channel
USB host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
300 Watt
Bluetooth
Audio Formats
WAV, WMA, MP3, FLAC, LPCM, OGG
Speaker System Details
1 x sound bar 120 Watt , 1 x subwoofer 180 Watt
Speaker Details
Sound bar - main channel - 2 x 60 Watt - 10% THD - 4 Ohm - active , Speaker - subwoofer 180 Watt - 10% THD - 3 Ohm
Built-in Decoders
Dolby Digital, DTS Digital Surround
Sound Effects
Sound Sync, Adaptive Sound Control (ASC)
AC 120/230 V (50 - 60 Hz)
USB host
Speaker System
System Components
Speaker Type
Active
300 Watt
Output Level (1m)
82 dB
Maximum Bit Rate Supported
24 Kbps
Maximum Sampling Rate Supported
96 kHz
Sound Effects
Bluetooth 4.0
Built-in Decoders
Audio Formats
Speakers Included
1 x sound bar - 120 Watt - wireless , 1 x subwoofer - 180 Watt - wireless
Speaker Details
Driver Details
Sound bar: 2 x tweeter driver , Sound bar: 2 x woofer driver
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 6"
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Digital audio input (optical) (TOS Link) , USB (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm)
Digital audio cable (optical), remote control, batteries, wall mounting bracket
Dimensions (WxDxH) / Weight Details
Sound bar: 89 cm x 8.5 cm x 5.5 cm / 2.4 kg , Subwoofer: 17.1 cm x 25.2 cm x 32 cm / 4.2 kg
Brand: LG
Price Range Ex VAT: 50 - 100
