The expansive 5.5" IPS Full HD+ FullVision Display gives you more to see. The 18:9 screen brings a dimension to the smartphone viewing experience. Immerse yourself in a whole new level of videos, gaming, and browsing.
The LG Q6's metal body is solidified by the lightweight "H Beam" frame made from incredibly strong 7000 series aluminum. It's designed to better endure impact from any direction.
Raise your selfie game with a 100-degree wide angle front camera to fit more friends and surroundings. The wide angle setting captures the whole scene, or set it to normal angle for closer, more personal portraits.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Whole lot of screen
The expansive 5.5" IPS Full HD+ FullVision Display gives you more to see. The 18:9 screen brings a dimension to the smartphone viewing experience. Immerse yourself in a whole new level of videos, gaming, and browsing. -
Durable metal frame - durable on all sides
The LG Q6's metal body is solidified by the lightweight "H Beam" frame made from incredibly strong 7000 series aluminum. It's designed to better endure impact from any direction. -
Wide selfie camera - me, you, and everyone
Raise your selfie game with a 100-degree wide angle front camera to fit more friends and surroundings. The wide angle setting captures the whole scene, or set it to normal angle for closer, more personal portraits. -
Square camera mode - share your squares
Create fun, share-worthy photos with LG's exclusive Square Camera. Four creative shot modes let you make unique and likeable posts, uploads, and shares. -
One hand operation - all with one hand
Reach everything, with just one hand. The slimmer 69.3 mm width makes the LG Q6 totally comfortable to touch, use, and hold. The flat display surface and optimized bezel reduce annoying accidental touches, frequent with curved displays. -
Face recognition - unlock with your smile
Lift your phone, and your face wakes it up. Improved face recognition unlocks your phone more quickly and conveniently than ever before, without typing, drawing, swiping, or fingerprinting.
- LG Q6 M700N - astro black - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- M700N
- Display
- LCD display - 2160 x 1080 pixels - 5.5" - 442 ppi - IPS
- Processor
- Qualcomm Snapdragon 435 MSM8940 / 1.4 GHz (8-core) - 64-bit
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 2 TB
- Operating System
- Android 7.1.1 Nougat
- Main Camera
- 13 Megapixel - f/2.2 - focus: automatic
- Front Camera
- 5 Megapixel - wide-angle lens - f/2.0
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- Wi-Fi, NFC, Bluetooth
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Talk Time
- Up to 1320 minutes
- Standby Time
- Up to 570 hours
- Astro black
- 69.3 mm x 8.1 mm x 142.5 mm
- 149 g
- Specific Absorption Rate (SAR)
- 0.277 W/kg (head) , 1.54 W/kg (body)
- Product Type
- Smartphone
- M700N
- Form Factor
- Touch
- 69.3 mm
- 8.1 mm
- 142.5 mm
- 149 g
- Body Colour
- Astro black
- Body Material
- 7000 Series aluminium
- SAR Value
- 1.54 W/kg (body), 0.277 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Navigation
- GPS
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- Wi-Fi, NFC, Bluetooth 4.2
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, digital compass, gyro sensor
- Additional Features
- Face Unlock, Knock Code function
- Processor Number
- MSM8940
- Clock Speed
- 1.4 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 3 GB
- Internal Memory Capacity
- 32 GB
- User Memory
- 22 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 2 TB
Front Camera
- Sensor Resolution
- 5 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.0
Main Camera
- Sensor Resolution
- 13 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Automatic
- Camera Modes
- Gesture Interval Shot, GIF animation function, Square Camera
- Light Source
- LED light
- Video Resolutions
- 1920 x 1080 (1080p)
Display
- LCD display
- Technology
- IPS
- Diagonal Size
- 5.5"
- Display Resolution
- Pixel Density
- 442 ppi
- Display Languages
- Danish, Hungarian, Czech, Icelandic, Basque, Croatian, Slovenian, Slovak, Ukrainian, Galician, English, German, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Japanese, Chinese, Korean, Kazakh, Macedonian
- FullVision display
- Connector Type
- Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Technology
- Lithium Ion
- Capacity
- 3000 mAh
- Talk Time
- 1320 minutes
- Standby Time
- 570 hours
- Run Time Details
- Talk: up to 1320 min , Standby (3G): up to 570 hrs , Talk (3G): up to 960 min , Standby (4G): up to 540 hrs
- Included Accessories
- Power adapter
